I like the idea of drilling the holes from the backside first.If running the 4 screw holes C bores you might drill the but end first with a simple tool so getting a more precise location, then with a piloted counterbore for the difficult end with having an extension shank on your C bore tool.
Having the 4 screw holes in place will guide the C bore tool when it comes in from the long nose end.
I only need to make 3 for now.How many you have to make? It is important, will change the answer from "just drill it and use a long hss endmill in an extension on a bridgeport" to "have someone make a long cbore step drill"
Sent from my moto g(7) play using Tapatalk
I have a few back spotfacers in a drawer, but plenty on ebay
METCUT 150 5237 HSS BACK SPOTFACER BALANCED DRIVE | eBay
back spotfacer | eBay
404 Resource at '/content/kennametal/images/pdf/brands/METCUT_catalog.pdf' not found: No resource found
Be careful to get the matching shank; piecing the system together may result in stuff that won't work. I have a shank for a back spotfacer, it locks up, the edges will rotate in the correct direction, etc....But the shank has a Morse Taper, useless for back-side work.
I realize you need something to pass through a 3/16" hole, and the stock catalog items don't go that small (only .3125"). However, you now know the stuff exists, you may need a custom item, or another vendor.
Notice
