Deep Drilling
Likes Likes:  0
Results 1 to 5 of 5
Thread: Deep Drilling
    Apr 2008
    Rochester, Ny
    11
    Default Deep Drilling
    Looking for ideas on deep drilling 6061 10X's the ID of .753 Id love one pass with a 63 or better surface finish. I have spindle thru at 250psi and upwards of 20 hp available.
    Jan 2006
    Houston, TX
    6,072
    565
    1036
    Gun Drills do that every day...
    Aug 2002
    West Unity, Ohio
    25,411
    5668
    8087
    GEN3SYS, GEN2-TA, Original TA, AccuThread, AccuPort, Twist Drill, Structural Steel, Drilling, Reamer, Threading
    Allied will hold that depth finish for a while, but will soon fade.
    250PSI will help, more would be better.
    I was talking about their TA spade drills. Not sure how Gen#sys does in alum?
    Think Snow Eh!
    Ox
    Mar 2005
    Silicon Valley, California... + other states & several countries on 3 continents
    2,100
    41
    As Ox said... Allied will fade. However for note.. their GEN 3 system rocks in aluminum...
    Could just chase the hole with a reamer and let the Allied just blast away...
    Gundrills will work quite well but slower...
    Aug 2007
    Northern Utah
    432
    94
    109
    10XD is not too bad....the 63 finish is a bit tougher. .753 is a bit of an odd diameter also....because of those 2 things...I would say gundrill. Cycle time is going to be a bit (alot) slower, tho the results are amazing. I like Drill Masters Elderado (gundrill guru's) for no other reason than their tech support is unmatched.
