deep pockets 7050 aluminum thin walls pushing out with finishing
Results 1 to 13 of 13
    Jan 2012
    Savannah, Georgia, USA
    1,672
    2625
    638
    Default deep pockets 7050 aluminum thin walls pushing out with finishing
    I am programming a aerospace part in aluminum 7050. Okuma mu6300. Part is held in dovetail and is tabbed to finish. This pocket is 2. x 6. x 2.0 deep. One wall is .06 thick and is pushing out when finishing. I cannot get it to size without going negative stock to leave. I have tried roughing and finishing in 2 steps roughing in 1 step, leaving wall at .140 and finishing in steps. Both ways wall is not flat and is over and on size in different places. I have tried a mix of 3/4 sharp 4flt and 1/2 Em .125r. Anyone have any tips for these kinds of walls. For example EM diameter, flute count, corner radius size, amount for finish pass etc.
    steve austin
    May 2019
    989
    345
    470
    I am far from an expert but I have gotten out of similar situations by taking a very heavy finish cut and by playing around with conventional vs climb milling. Is if possible to make a "hoop" to support the outside and climb mill it (should help push the thin wall into the temporary support)?
    Dec 2014
    CANADA
    British Columbia
    1,288
    361
    590
    Take a look at something like this: Machining Thin Walls and Floors
    Nov 2010
    Tustin, CA
    430
    266
    129
    Possible to machine the pocket first and then the outside? Or could make a plug to go in before you finish the outside.
  5. Likes Mtndew liked this post
    Jan 2019
    Arizona
    1,005
    91
    366
    foam on the inside work really well, but I am guessing your running production and dont want the add'd start and spot time.
    if thats the case rough both outside an inside leaving maybe .1-.150 stock then when you do finish pass's step down about .250 alternating between inside and outside and make it so one side finishes deeper then the other side to help hold rigidity.
    I use 3 flute alumastars for deep pockets. I am assuming your tolorance is either + or - .003 or .005
    On longer lengths in either x or y you maybe have to run some taper in the program as we have had the center sucking in about .002
    also once you get deeper you will have to reduces the rpm by about 1/2 to keep the chatter away and a nice finish
    Hope that made sense.
    for example
    outside 1st fin pass at z-.125 deep
    then go to inside 1st fin pass z-.250 deep
    then go to outside 2nd finish pass z-.350
    then go to inside 2nd finish z-.500
    etc etc
    the other thing that helps with this is if you use a tool with a shorter flute length. and let the dia of the endmill above the flutes rub on the part. that actually helps stabilize the part.get a standard length 1/2" endmill and stick it out the total depth of your part. I assume your also tumbling them , if so you wont see any rub marks. if not then scotch bright is required. we tumble all out parts and never have a problem doing it this way.
    Apr 2018
    4,693
    2105
    Quote Originally Posted by Delw View Post
    foam on the inside work really well...
    I was going to say I've filled the adjacent area with wax, if there is one ...
    Mar 2011
    SWITZERLAND
    1,037
    125
    426
    What a stupid design of such an aluminium pocket! Certainly a wax fill is the way to go.
  9. #8
    Jan 2014
    Temecula, Ca
    3,276
    1396
    4271
    we used to use reverse spiral end mills for that. (ie right hand cut, left hand spiral) Without seeing the part its hard to guess, but clay or wax on the outside could help.
  10. #9
    Sep 2002
    People's Republic
    4,607
    450
    2781
    .06 2 inches deep, if you cannot support the outside........what tolerances are you dealing with?
    Is it the 6 inch long wall?
  11. #10
    Mar 2015
    Michigan
    443
    100
    155
    I'd try ramping the finish passes on those walls instead of stepping it down.
  12. #11
    Sep 2018
    Arizona
    22
    7
    I'm sort of surprised no one has said this (maybe i missed it?) but we do parts like this quite frequently.
    Get rid of those big tools. way to much tool pressure.
    I use SGS reduced neck tools but any brand should do, try a .375 or .250 cutter. The one I have in the machine right now is .250D , .250LOC 4" OAL, I think it has a .030r.
    In an SK holder or Hydro I run it balls out 15k on the genos, 45ipm .025-.1 DOC.
    YMMV
  13. Likes aarongough liked this post
  14. #12
    Jun 2019
    Maryland
    434
    76
    a huge problem I have run into in the past is 7050 moves all over the place ( reliving itself) and is very hard to get consistancy. I had 1 that was a housing 20x 30 " x 4 with .04 walls 4 inches deep ,so all the way through. I did the outside profile first. then built a 1 inch thick box that slid over the outside. then machined the inside. it had .13 radius in all corners. it had 2 chambers. I cut the small 1 out first. then made a block that slid into that. then I was able to finish the big chamber without the center wall blowing or collapsing.
  15. #13
    Jan 2010
    Gilroy CA
    4,406
    3186
    2477
    Rough the part outside and inside tapered like a cone. Then finish in steps outside / in side with a 3/8 or 1/2 tool. I'd make sure I was taking a spring pass at each level as I went down. If your runnout isn't perfect and you leave some steps get a lower helix tool (35-37*) aluminum tool with 2" of flute and take a spring pass at the bottom level to clean up the wall. We do tons of parts with 1/8" thick tabs stick off the side of parts like you are talking about that are 2" from the base with this method. Have to hold +/-.002 on the tab thickness
  16. Likes CNC Hacker liked this post
