muchogustl
- Jan 18, 2020
I thought I would try asking this here, because it makes no sense to me and I have no one else to turn to. I'm using a Haas vertical mill version 2 (I don't know the details, but they should not matter).
I made a simple change to a program to speed it up because at first I was concerned with going too deep in one cut. Because it was so slow and the milling calculator had it at feeds of like 40 IPM while I couldn't go above 10 without breaking the mill, I tried to just cut deeper and go in one pass.
When no end mill broke, I thought it was fine. Then I found out it wasn't moving the .013 on the X for the return cut for some reason. I have no idea why. ncviewer.com has the new version looking right, at least.
Can anyone tell me why the second (one .025 cut) version does not move in the x direction? I also have questions about basic surface speed calculations and my tendency to go high on RPM and low on feed, but I hope that is something I can look up and just have not done thoroughly yet.
Here is the two-cut version:
(GROOVES)
( TOOL 8 - 1/16 ENDMILL )
(1ST GROOVE)
(1ST CUT)
G00 G17 G40 G49 G80 G90
T8 M06
G00 G90 G154 P10 X2.829 Y0.1 S4500 M03
G43 H08 Z0.1 M08
G01 G90 Z-0.013 F4.
G01 Y-3.1 F6.
G01 X2.842
G01 Y0.1
M01
( 2ND CUT)
G01 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X2.829
G01 Y0.1
G01 Z0.5 F30.
(2ND GROOVE)
(1ST CUT)
G00 X6.899
G01 Z-0.013 F4.
G01 Y-3.1 F6.
G01 X6.912
G01 Y0.1
(2ND CUT)
G01 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X6.899
G01 Y0.1
G01 Z0.1 F30.
G00 G90 Z0.5
M01
and the updated, one-cut version:
(GROOVES)
(1ST GROOVE)
T8 M06
G43 H08 Z0.1 M08
G01 G90 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X2.842
G01 Y0.1
G01 Z0.5 F30.
M01
(2ND GROOVE)
G00 X6.899
G01 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X6.912
G01 Y0.1
G01 Z0.1 F30.
G00 G90 Z0.5
M01
Thanks for any help you can give
(GROOVES)
(1ST GROOVE)
(1ST CUT)
T8 M06
G43 H08 Z0.1 M08
G01 G90 Z-0.013 F4.
G01 Y-3.1 F6.
G01 X2.842
G01 Y0.1
M01
( 2ND CUT)
G01 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X2.829
G01 Y0.1
G01 Z0.5 F30.
(2ND GROOVE)
(1ST CUT)
G00 X6.899
G01 Z-0.013 F4.
G01 Y-3.1 F6.
G01 X6.912
G01 Y0.1
(2ND CUT)
G01 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X6.899
G01 Y0.1
G01 Z0.1 F30.
G00 G90 Z0.5
M01
(GROOVES)
(1ST GROOVE)
T8 M06
G43 H08 Z0.1 M08
G01 G90 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X2.842
G01 Y0.1
G01 Z0.5 F30.
M01
(2ND GROOVE)
G00 X6.899
G01 Z-0.025 F4.
G01 Y-3.1 F6.
G01 X6.912
G01 Y0.1
G01 Z0.1 F30.
G00 G90 Z0.5
M01
