Device to load program into rs232 port on cnc
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Mar 2010
    N.E. PA
    802
    85
    249
    Default Device to load program into rs232 port on cnc
    I need a portable device to load programs into a rs 232 port on a cnc machine. Programs would be copied off a main computer using usb port or rs232 port I have not found anything searching the internet.
    John
    Dec 2007
    458
    931
    64
    Jul 2006
    Arizona
    4,689
    18607
    4532
    Old cheap laptop works just fine--just a little bigger than one of those hand held gizmos.
  4. Likes IronReb, blkaplan liked this post
    Jan 2014
    Washington
    4,724
    856
    2564
    I've used these guys product years ago when it was just a floppy drive to RS-232. Solid product, but IIRC pretty expensive.
    Greco Systems USB Minifile, Greco Box
    Mar 2014
    CANADA
    Ontario
    804
    804
    161
    I have not used any of these myself but Here is few;
    Highland DNC, LLC.
    USB devices | Product Categories | Calmotion
    Mar 2014
    BLACK MOUNTAIN NORTH CAROLINA USA
    360
    356
    234
    If it is multiple machines , you might want to look at CIMCO , I've used them and their product for yrs
    Oct 2007
    detroit,mich.
    4,704
    4710
    418
    Quote Originally Posted by Philabuster View Post
    How do you connect the other end of the RS-232 cable, to the lap-top? An adapter for THAT would be WAYYYYYY too convenient!
  9. #8
    Jul 2002
    Irvine, CA
    553
    14
    Quote Originally Posted by jdj View Post
    Maybe?
    USB to Serial Converter RS-232 - 2.25 ft : Display Solutions | Dell
  10. Likes jrmach, aj liked this post
  11. #9
    Aug 2005
    CT
    7,834
    326
    1866
    Hmm... up-'til the mid 2000's, serial and parallel ports were standard issue on most laptops, even the cheapest bottomfeeders.
    The ultra thin ones sometimes had a PCMCIA slot, for which you can get almost any adapter card from memory to modem and serial/parallel port.
    My HP is from 2008 and it still has 2 (9 pin) serial and 1 parallel ports.
    On edit:
    If you need something all modern, you can still go with a Dell laptop and add this thing for just under $60: http://accessories.us.dell.com/sna/p...=baynoteSearch
  12. Likes jdj, Philabuster liked this post
  13. #10
    Jan 2003
    Temple, Texas
    2,372
    15
    239
    The USB to serial thing is pretty cheap on ebay ~$2
    USB 2 0 to Serial RS232 DB9 9 Pin Adapter Cable PDA Cord GPS Converter SY | eBay
  14. Likes jdj liked this post
  15. #11
    Mar 2010
    N.E. PA
    802
    85
    249
    After looking over all the options and our main problem is the floppy discs themselves. I had some NOS floppys fail out of the box so it is time to change. The cheapest way is to change the floppy drive unit to one that takes a usb connector so I can use a sub flash memory device. I will still only have 1.44mb of memory but that is plenty for me. Other options were to get a $600 portable device or wire in a network but since I do have computers at each cell of machines and the floppy drive replacement is $ 21 bucks that is the way I'm going. I hate to be the one that would drop the portable $600 unit while using it.
    http://www.amazon.com/Generic-SFR1M4...y+usb+emulator
    John
  16. #12
    Dec 2007
    Central Ohio USA
    3,864
    82
    1739
    For those going down the laptop/netbook path, I've had good success with the I/O Gear USB-to-RS232 adaptor. It has a yellow LED showing signal activity. Mounts up fine on Win.AnythingSoFar, and connects well to diverse items such as a DynaPath 50 controller and various broadcast video devices.
    Chip
  17. #13
    Feb 2015
    32
    25
    36
    I use my laptop. I only operate one lathe, but, keep all my shop notes, time sheets, g-codes, etc, on my Toughbook. This works great for me, until I loose the computer. You just need to build the cable, and I would be happy to get that info from the shop in the morning, as well as the terminal program for the computer. This is a great way to go, as you would also be able to write and edit on the laptop as well as store and catalog on it.
  18. #14
    May 2011
    Shreveport/Louisiana USA
    1,783
    1669
    1106
    We use a laptop as well and it works great for our situation.
    One uses RS232 and the other is USB, I have a custom built box just for the lap top to keep it protected from the not so nice shop environment.
    I ordered the cabling, RS232 to USB adapter and null modem (goes between the adapter and serial cable, I dunno WTF but wont work without it) for $30.
    If you go that rout you will need software on the PC that lets all that work. We have cam software but there are programs like EasyDNC that I have used that work great, I think
    EasyDNC is like $130 or so, there are others I am sure and maybe even some old freeware.
    You wouldn't need a high end laptop by any means at all, even an 5 year old PC would handle this, just make sure to back up your files often.
  19. #15
    May 2011
    1,783
    1669
    1106
    OOP
    double post
  20. #16
    Apr 2007
    West Virginia
    1,071
    552
    427
    I just bought a refurbished dell desktop for $100 (looks new) Includes win 7, has serial port, network conn, surplus monitor $25. Very reliable very cheap. I just setup a shares folder and load the files right to it. Or can put a usb stick in and load that way.
  21. #17
    Jan 2007
    Flushing/Flint, Michigan
    8,129
    415
    6708
    There has to be 100 ways to skin this cat which makes me wonder how hard you have looked.
    Laptop, easy, simple, straight forward and cheap. Very common, easy and clean.
    Smart phone and bluetooth or wi-fi box to plug into machine, compact, a bit of a pain to get working right.
    Wireless box you can move to machines and talking to your computer network is another. How about wireless laptop to your network and 232 port?
    USB to disk drive interfaces.
    I do not work in your shop so I surely can not "advise" on the best way for you and the best way for anyone 10 years ago may be very different today.
    (stick the part programs in the "cloud", black box to access???? Crazy new stuff but hmmm......)
    The list is just about endless today.
    Be thankful that you don't have to work with punched tapes anymore.
    Now I can connect to, program, and monitor a machine on the other side of the globe in less than a second.
    10 year old kids can get almost real time video out of China. Across your shop floor should be not a big deal.
    We are sitting in the middle of an explosion of data transfer. The tricky part being how to get the Fanuc OM-A 232 port to grab it's piece..
    Bob
  22. Likes aj liked this post
  23. #18
    Sep 2009
    Apex, NC
    1,510
    749
    Older Panasonic "toughbook" laptops can be gotten cheap on fleabay; these have serial and all sorts of ports. I bought a couple year old brand new one for $200, both for talking to a heidenhain controller and Plc programming. Serial to USB "usually" works, but why risk it or try to track some phantom problem due this extra layer of conversion. Panasonic and dell still make laptops with serial ports for industrial use. Craigslist also usually has some Toughbooks for sale if in a fairly large town.
  24. #19
    Dec 2015
    Florida
    5
    Default ShopLink FLASH 2.0 will solve your hand held file transfer needs
    Greetings, my company Highland DNC make a popular low cost device called ShopLink FLASH, only $229 + $7 shipping. We have out sold all our competitors with OVER 1300 sold. We have installed our units on all Gcode compatible CNC controls with flawless operation. See www.highlanddnc.com or call 941-322-2286 for more information. YES drip feed (DNC\TAPE) a program up to 2 gigs long, WOW!. The reason we sell 10X more than anybody is US\Florida based customer service 24\7, if your phone call isn't answered email [email protected] and I will call you (US only).
  25. #20
    May 2016
    Colorado
    9
    6
    A laptop works fine (I use an older Thinkpad for this). If you want some really portable, and USB to serial works with your machine (it may not), then you could use a small Android tablet or phone, or a Raspberry Pi.
