Hello!
I have what might be a bit of a dumb question in that there's probably a very simple answer.
Is there any geometric difference between a double angle cutter and a single point thread mill? I need to make very small grooves (~.015in deep) into a little piece of steel, but I need the grooves to be flat instead of angled like a thread. The purpose is to be the lock to a slide that runs along a rack of sorts. Instead of a gear, it's just gonna be a spring loaded nub with some teeth on it to lock into the grooves on the rack. My tooling is fairly limited, but I have a large (.750 diameter) double angle cutter that has the required 60 degree angle, as well as a small thread mill that will get the job done with less worrying about clearance.
Is there any functional difference between a thread mill and a double angle cutter? Since I'm not cutting threads, I'd rather not find out in practice if I can help it.
Gregg
Gregg
