Hello
Customer of mine has got 2 brand new DMG MORI machines with Celos system 2019, one on Fanuc, the other on Mitsubishi.
I would like to communicate with NCU or PLC and read runtime infos, like spindle speed or feed override.
I am not able to terminate Celos system without switching the whole machine off and get to Windows to run any underlaying original software from Fanuc or Mitsubishi.
I have already connected several older Fanuc machines, so I know that I need at least IP address of embedded ethernet port and TCP port - both are normally accessible in original Fanuc software.
I have no experience with Mitsubishi so far, but MELSEC is pretty good documented. Problem is the same - IP address, protocol and port.
Thank you in advance
Any help would be appreciated
