Hi,
I need to add a VFD to run the 3 phase spindle motor on my Clausing Kondia FV-1 that has a Dynapath Delta 20 installed. According to the schematic pdf, and by inspection, it looks like I can just run 220V single phase to the two step down transformers to run the rest of the controller. Can I just detach the three wires from the fuses that go to M1 for the spindle control, or will the controller fault do to no power being present on that circuit?
Page two on this pdf: http://www.dynapath.com/us/data/files/mcp_delta/4203642Delta10-20MCP2WiringDiagram.pdf
Thanks for any advice.
Jeff
Jeff
