DNM500 TSC rotary union replacement
Results 1 to 5 of 5
    Apr 2007
    Pillager, MN
    5,703
    1863
    5174
    Default DNM500 TSC rotary union replacement
    The rotary union on my DNM500 is shot. Leakin'...........The ceramic surfaces are chowdered. Replacement is $1200?!!!??? Huh? Is that correct? A fitting with two pieces of ceramic sandwiched in the middle.............Are they machine specific? Off the shelf? Easy fix, spendy lil part......................
    Feb 2007
    Aberdeen, UK
    3,505
    1217
    1311
    I've replaced two of ours over the last half a dozen years or so.
    Direct from Deublin, about £350.
  3. Likes Vancbiker, 3t3d liked this post
    Jan 2010
    Gilroy CA
    4,379
    3165
    2436
    Quote Originally Posted by gregormarwick View Post
    I'm not a huge fan of Deublin...
    I've change our Doosan DNM500 one 2 times in 9 years. I've also changed the one in my Yasda two times in 3 years (2016 Yasda probably has more cut hours runnign 24/7 then the 2010 Doosan LOL). We reduced the 1000 PSI pump from Chipblaster to 900 PSI . Hopefully solve that issue.
    Jul 2012
    Washington
    2,745
    1049
    1078
    Not a direct comparison but ceramic seals in a coolant pump that I run around 70 psi. I used to replace them every year or two when I filtered to 20 microns nominal, bag filters. Since I started filtering to 1 micron absolute, cartridge filters, I haven't changed one since, and it's been around 12 years or so. This is grinding stone, ceramic, and quartz.
    Jan 2010
    Gilroy CA
    4,379
    3165
    2436
    Quote Originally Posted by DavidScott View Post
    How are you filtering? The yasda has a 5 micron filter I think.
