nicholasfreres
- Sep 26, 2021
I've recently been assigned at my workplace to operate a Doosan vertical machining center, a 750/50. All I do with it is face milling, nothing else. I keep an eye on the spindle load meter, which is marked in segments of blue (below 100%), yellow (100% to 200%) and red (above 100%).
At what I take to be reasonable RPM (350) and feed-rate (45) and depth of cut (.09 to .06) using a six-inch shell mill, the load meter is almost always in the 140% to 180% range.
Is that too much load on the spindle to sustain all day long, day after day? Am I running the risk of damaging the spindle?
