Does it do it in MDI or just when you run a program?
Hi Bill, Im using Fanuc Control I-series.
Look at parameters 6071 to 6079, these relate to program numbers O9001 to O9009 called as Subprograms and parameters 6080 to 6089, these relate to program numbers O9020 to O9029 called as Macro Programs. Whichever parameter has "6" registered, will point you to the program number of the Sub, or Macro program you need to modify.Hi Bill, Im using Fanuc Control I-series.
Fanuc Oi-F control. Check which program runs when tool changes. The below program is from a Doosan. It will be O9001 or O9006. G30 X0 Y0 position depends on a parameter, #1241.
O9001(DVF5000 A1 M06 W0 TM 20180419)
IF[#1007EQ1]GOTO600(MACRO M CODE MST SKIP)
#14=#4114(REC SEQ NO)
#15=#4001(REC G1 G0)
#16=#4003(REC G90 G91)
G31
IF[#1000EQ1]GOTO500(HEAD=T)
IF[#3010EQ-1]GOTO500
G05.1Q0
N10G80G40
N30G91G30Z0.M19M222M233
M39
N40G91G30X0.Y0. (Change this line or comment it out. I wouldn't delete because it does come in handy)
N50M06
N60
M232M223
N500
N#14G#15G#16
G05.1Q1
N600
M99
Regards,
Bill
Notice
