Doosan Lathe Coolant Lines??
Likes Likes:  0
Results 1 to 6 of 6
    Nov 2019
    Indiana
    Default Doosan Lathe Coolant Lines??
    Hello All,
    I'm new to this site. I apologize if this isn't in the correct location! I'm looking for some braided coolant lines for our Doosan Lathe. Our tools use an 1/8 BSP Adaptor and the only way to hook it up to the machine is either with a 15mm brass ball that has the same threading in it or to an m8x1.25 threaded hole in another brass fitting that came with it. Do you know where I can purchase these or where to start looking I can't find anything! Locline has npt threads but I can't find any type of banjo bolt to accomodate that. Qpm has some stuff but nothing with a big enough thread to use the ones that I could get with iscars coolant hoses. I'm lost!
    Jan 2007
    New Jersey
    956
    467
    472
    You can probably buy the right from Doosan. Have you called and asked?
    Jan 2003
    Canada
    11,274
    5418
    3406
    Sandvik has some hose kits for through tool coolant on lathes, comes with a few end fitting options.
    I bought one for my through tool parting blade but never tried it yet.
    I soldered pipes in most of the brass balls, works way better now. Also drilled out some of the set screws to cap them with .093 holes or so.
    Apr 2013
    south australia
    104
    32
    19
    What model lathe do you have? Our new Puma 3100 has a plugged 1/8 bsp port in the top and back of the external tool holders, these are actually plugs for the coolant passage drilling.
    Mar 2014
    Southeast Massachusetts
    186
    13
    62
    The ports drilled on all my doosan blocks are BSPT.
    I bought a few adapters from McMaster, so e straight and some right angle, that go from BSPT male to bspp female.
    I then use the sandvik hoses that have bspp threads. The sandvik hose kits also come with 15mm ball adapters to bspp thread.
    Jun 2011
    New Jersey
    877
    527
    340
    There was a place in Canada that sold hose kits and such. You may want to google it. The Sandvik units are very high quality as well.
