Doosan Lynx Live Tooling
Results 1 to 9 of 9
    Aug 2018
    Iowa
    13
    Default Doosan Lynx Live Tooling
    Can anyone tell me if there is a parameter I can change so the live tools are on center?
    Jan 2007
    New Jersey
    920
    441
    436
    I work for Doosan, I can try to help. First, I need the exact model number, serial number and date of build. After that, I can try to lo0ok up this info. Or, maybe quicker, you can call service at 973-618-2500. Did you even try calling us for service questions first? It's usually good practice to give as much info straight away in order to get help fast. Saying you have a Lynx means nothing. There are many models.
    It sounds more like the turret is out of alignment. If it has a Y Axis, there might be a parameter but even with that, it still seems like the turret is out. Have you tried checking the turret? If there is no Y Axis, the most certainly the turret is out.
    Paul
  3. Likes ljeremy578 liked this post
    Aug 2018
    Iowa
    13
    Lynx 2100LSYB
    Serial # ML0406-000181
    11/2018 is the build date.
    I was just curious if you could set the live tooling at zero instead of having to offset a tool to find the center everytime.
    Jan 2007
    New Jersey
    920
    441
    436
    OK, first, indicate the face of an empty tool spot. If it is off, then you have a turret alignment issue and the machine was probably bumped or crashed. We know these things happen. If the tool is off center a lot, then you most likely have a turret alignment issue. If the tool is only off center a couple of tenths, this is "normal". If you need help, call the number above and you will get instant help. I am an applications engineer, not service. Darryl Hardt is your service contact. Walking you through this here is not the best form of service so please call and you will get the help you need.
    Paul Anderson
    Applications Engineer
    Doosan Machine Tools America
    [email protected]
    973-618-2457
    Aug 2018
    Iowa
    13
    I think you are misunderstanding what I am asking. I want to know if is a way to set you Z for live tooling so it would technically be at zero. For a drill I currently need to offset the difference to find the center of the drill.
    Jan 2007
    New Jersey
    920
    441
    436
    I didn't misunderstand anything. You did not state your case in the first post or the second. The answer to your last question is to set your endmill or drill with the Q-setter and set a tool offset for that tool. There is no parameter to set because every tool will be different. That's what tool offsets are for. If you want, you can put, say, a .500 pin in the tool holder, use that to set the Z with the Q-Setter. That offset will not change for that tool station unless you physically change something.
    Paul
    May 2019
    Montana
    30
    19
    18
    Quote Originally Posted by ljeremy578 View Post
    Not to pile on, but damn man, you're barely using English here... I have no idea what you are asking either. You asked about Y center, then mentioned Z. Huh???
  9. Likes TeachMePlease liked this post
  10. #8
    Aug 2018
    Iowa
    13
    Sorry I thought I had explained it better. Just wanted to know if you set the z to zero.
  11. #9
    Jan 2007
    New Jersey
    920
    441
    436
    You set the Z to zero for each tool station by using the tool setter. Then you set the part Z to zero by using a tool, usually a turning tool, by calling it up with it's offset and touching off on the part zero and setting your work offset. Now I may be misunderstanding something so I am going to ask a question and not try to insult you. Are you new to turning? These are things any qualified turner would/should already know and this applies to any CNC lathe. So be honest. If you ask vague questions you will get vague answers simply because you don't give enough info. That doesn't help you and doesn't help people who want to help you.
    Paul
