Eric U
Hot Rolled
- Feb 26, 2003
- Eastern AL
Hi all,
Don’t know if I really have a problem but suspect I do. Normally, if I do a full day of machining I would typically get at least 3/4 of my coolant skimmer tank full. I can’t remember how long it’s been since I’ve emptied it…at least a couple of weeks and I’ve been hitting it pretty hard. It’s about half full.
I’m using way lube, but not much. Maybe 1/2” from the tank over an 8 hour day. If I push the manual button on the lube pump the pressure does go up but then immediately goes back down. My foggy memory remembers it staying pressurized for at least a little bit after actuation.
Are my linear rails not getting enough lube now? Is the pump dead, plugged, or? I’m guessing it’s not an open line somewhere as the lube would all leak out or my tramp oil would fill even quicker. How to diagnose?
Thanks for any and all help,
Eric
Eric
