baran3
Cast Iron
- Jan 28, 2007
- Littlestown PA
I am looking for opinions on comparable CNC milling machine tool brands to Doosan. I am interested in machines that are on the same level or higher quality. Example as if someone has the opinion of, "for the amount of money you spend on a Doosan you might as well spend a little more and get a XXXX machine". I am also interested in general opinions of the brand. I have a DNM400 and may be thinking of getting another mill in the future. I am happy with the Doosan, but also want to explore other possibilities to some degree. I am a small shop. Don't do much production. Most stuff has a high emphasis on tolerance and appearance. Work mostly with aluminum, but of course will cut almost anything that comes through the door.
