Doosan Puma 2600 lathe subspindle/tailstock question
Results 1 to 4 of 4
    Jul 2019
    Illinois
    Default Doosan Puma 2600 lathe subspindle/tailstock question
    Hello
    Im new to the forum and have a question for the Doosan lathe gurus here. I am programming a Puma 2600 SYII (fanuc controller)to use the subspindle as a tailstock. I turned a dead center and have it clamped in the subspindle. I have had great success with it so far but had a question about how much thrust this dead center is putting on my part.
    My program is basic and I am using a G300 command to advance the dead center into the part. After all machining, I am using a G301 to cancel the torque control command.
    My question is how can I adjust the amount of pressure put on the part?
    Thanks in advance!
    Nov 2007
    The South
    169
    12
    Sorry that I can't remember for sure, but I seem to think this is in the blue and white Programming Manual that came with our 2600SY. Maybe the argument is the B or S in the G300 line? I do recall seeing this information in the documentation somewhere. Hope this is helpful...
    Sep 2012
    Finland
    14
    John is right, we had manual with diagram as well, this is from older control, not sure if it applies to you, but "most likely / test carefully" and B it is.
  4. Likes Triaged liked this post
    Jul 2019
    Illinois
    That’s it!!! Thanks for the help fellas! I knew I came to the right place!
  6. Likes Triaged liked this post
