nightsky84
- Nov 26, 2019
We recently bought a dual spindle dual turret Doosan lathe. I'm using mastercam to program it. There is an upper and a lower button on the panel which allows you to control whichever you want. During one of my programs I noticed my left spindle spinning in the opposite direction that I want it to for my drills. If i post an m03 s100 p11 while upper is selected it goes ccw like it should. If i post this same code while the lower is selected it goes cw. Is it supposed to do this or am I needing to change a parameter? My drills are all posting out an m3 code which is right even if i create a tool and specify that direction but the lathe is wanting to do the opposite! Let me know if anyone knows about this! Thanks!!
