Double disc ground MIC6 and post-grinding machining
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    May 2004
    2,511
    886
    1640
    Default Double disc ground MIC6 and post-grinding machining
    I've got a customer in the design phase of some small (6" x 12") aluminum assembly machine pallets that need to be consistent above all else. 2 prototypes, 30 piece orders, up to about 100-120 or so total. The customer is asking me what is reasonable for a flatness callout, not providing a target. Thickness is up in the air, but I'm thinking 3/4" since MIC6 is spec'd .005" flatness at that thickness, but .015" flatness in anything thinner. Just seems like less hassle and more stiffness for a couple bucks more in material.
    Main question: If I get TCI to cut oversize and grind to .002" flatness for me (the tightest they will quote), what are the chances of me bolting this to a nice flat fixture, machining the pictured features, and the plate staying flat? I know I'd be in for a fight with 6061, less so with 7075, but what about MIC6? We'll be using sharp tools, taking it easy on the roughing, good coolant, etc.
    Sep 2017
    Wisconsin
    801
    129
    438
    Is there a hardness spec? Could you use tooling (jig) plate?
    May 2004
    2,511
    886
    1640
    Quote Originally Posted by Rick Finsta View Post
    Isn't that what MIC6 is?
    No hardness or any other material spec other than they are cool with whatever alloy, as long as it's hard anodized.
  4. Likes sfriedberg, Ox, wheelieking71 liked this post
    Jul 2006
    Hillsboro, New Hampshire
    7,843
    1831
    5515
    3/4" sounds like a good choice, at least it "seems right" looking at the model. I think you should have a stable part when the machining is done, but you may want to rough first, remove the burrs, and check on a surface plate before final machining. You may see a little variation in remaining stress in the raw stock, but it's supposed to be stable.
    If there's enough money in the project, rough the plates in a vise, then make a vacuum fixture to locate and finish all the critical geometries. Low stress clamping for light machining, minimal distortion in the final part.
    Nov 2014
    Colorado
    2,978
    3495
    836
    Quote Originally Posted by [email protected] View Post
    <snip>
    I don't have anything useful to add but just to say that there isn't anything in (predominantly) aluminum alloys that is dimensionally more stable.
    In terms of stability there isn't anywhere else you can go (up from that , that I'm aware of ? ).
    Beyond that double sided tape or a vacuum plate ? (I haven't tried the super glue thing yet ).
    Sounds like you know how to machine it.
    For precision optical stages there are specialists in aluminum grinding for micron level -ish flatness (but doesn't seem you need that).
    I'm being pushed / nudged towards aluminum castings simply for their stability.
    There may be some other alloys used by instrument builders (for long term stability) that are in the bronze and brass direction... [Probably not necessary / appropriate ].
    I believe Mic6 is relatively forgiving for further heat treatments and you can "Re-set" the alloy easily without leaving permanent "artifacts" in the metallic structure.
    I had no idea that the price difference between let's say 6061 and MIC6 was so close to be worth while ?
    Cool idea !
    ___________________________
    Now I see Milland beat me too it pretty much. (slowpoke).
    Aug 2005
    CT
    7,834
    326
    1866
    Matt, I have made tons of repeat fixtures out of MIC6 whenever the customer specified just a plane-jane "jig plate" or .750 plate, and never had any issues.
    I honestly did not know that they are specced at .005 flatness, just took it for granted that a jig plate is better than what I can achieve inhouse.
    Some of those fixtures were as large as 48 x 30, and they had to fit a mating receiver made 10+ years in the past, and they've all fit like a glove.
    No shrinkage, warp or flatness issues whatsoever.
    The nice thing about MIC6 is that it will anodize uniformly, and in some cases customers specified "aesthetics" on the print with either "color" anodize or black hardcoat.
    Though I have not looked into it for 10+ years now, but I have had one rejection due to blotchy appearance after anodizing.
    I was told that a "jig plate" is what it is, a cast plate that is milled to specs without care for the alloy, so there can be visual differences after plating.
    A MIC6 however is 6061 cast plate, and it should be uniform.
    (again, this is only what I was told, so since then all "jig plate" for me is MIC6 )
  8. Likes cameraman, doug925 liked this post
  9. #7
    Nov 2014
    Colorado
    2,978
    3495
    836
    Quote Originally Posted by SeymourDumore View Post
    <snip>
    That's pretty valuable re: cosmetics of MIC6 … I just assumed that was the Achilles heel for MIC6... Good to know.
    20 years ago where I used to work we had this ultra thick hard coat that was almost like a salt and pepper / speckled grey finish that would hide a multitude of sins.
  10. #8
    Jul 2010
    corvallis,or
    877
    89
    369
    I've used Mic6 for fixture plates that we removed a whole lot more material than yours and hit .002 flatness without much trouble. Seemed very stable. We started with 1.5" and milled it down to somewhere around 1.25" with large pockets. We also used stuff called K100 (I think) which was mostly the same but maybe a little cheaper.
    Parts were nickel plated afterward for durability. I really liked the look.
    Sent from my XT1710-02 using Tapatalk
  11. #9
    Feb 2016
    Washington
    189
    438
    103
    You can also look into ATP-5 plate. I found it for a job requiring a bunch of fixture bases and ended up using it over MIC-6. It was cheaper and ended working well for the project. I didn't design the parts, so i'm not sure what our flatness requirement was for them.
  12. #10
    Oct 2007
    SPAIN
    3,664
    2080
    1370
    I thought MIC6 was a 7000 series material?
    And "general ally tooling plate" in the UK is 5000 material
  13. #11
    Nov 2002
    3,270
    1867
    812
    Per Trident Metals, NO. It is not. (Ask me how much $$$ THAT lesson cost me.)
    Mic 6 cast plate, is just that. Mic6.
    Tooling plate AKA Jig Plate, (at least around here) is 6061-t6, but has different flatness & parallelism, and is also marketed differently.
    Doug.
  14. #12
    Nov 2002
    3,270
    1867
    812
    Quote Originally Posted by barbter View Post
    Per my suppliers here: Mic 6 is "whatever" scraps, bits, remnants they have left over, are melted down, cast, and ground flat.
    There is no uniformity from batch to batch. That is why Mic 6 anodizes blotchy, and is different with every HEAT.
    Doug.
  15. #13
    Jul 2011
    New York
    34
    23
    32
    I believe that flatness spec is across the entire plate when it's manufactured. A 6" x 12" section will likely be flatter from the mill than you can easily achieve through secondary processes. Also, ATP-5 is spec'd at .005" flatness in all thicknesses.
    About 90% of the work I've been doing lately has been QC jigs in ATP-5 for a major 3D printer manufacturer, typically about 9" x 12" x 3/4 - 1 1/4" thick. We haven't observed any warping or creep measurable with our tools, even with sections milled as thin as 1/8". The customer verified the parts on their CMM and found that even with a 3-part assembly and the associated tolerance stackup, the critical features were parallel within .01 deg.
    These were run on a Haas Super Mini Mill, so it's not like we have some crazy equipment or anything. It's just very stable and consistent material. I wouldn't overthink it too much if I were you, at least give it a shot without grinding first.
  16. #14
    May 2005
    CA
    1,133
    9
    291
    I believe it's somewhat difficult to get good cosmetic results when anodizing MIC6. The nature of it being cast can cause acid being "trapped" in the typical small voids in casting. Also, I believe the silicon content is not "consistent" as it is in wrought plate, which can also cause issues. Finding an anodize shop with a good amount of experience may be key in getting good results.
    jmho
    PM
  17. #15
    Aug 2005
    CT
    7,834
    326
    1866
    Quote Originally Posted by doug925 View Post
    Doug.
    I don't know Doug, in my experience MIC6 anodizes uniformly and consistently.
    I thought MIC6 was just the trade name for ALCOA's tooling plate.
    Mic6(R) Aluminum Cast Plate
  18. Likes wheelieking71, DavidScott liked this post
  19. #16
    May 2004
    2,511
    886
    1640
    Quote Originally Posted by precisionmetal View Post
    Thanks Pete. I've been hearing that as well, but the customer doesn't really care about aesthetics with this, it's just in-house tooling.
    With that said, my anodizer would rather deal with K100 because of the reasons Doug brings up, consistency and quality. I've worked with K100 before and liked it just fine. Do any of your guy's answers change regarding flatness issues with K100 over MIC6? TCI doesn't seem to offer it, but DIX does. Anybody else I should talk to that can supply double disc or blanchard ground blanks?
    And don't get caught up in tooling plate / not tooling plate. It's a non-issue for this project. As long as it's stable and it comes from a reputable mil, nobody cares what it's called or if it's 5xxx, 6xxx or 7xxx series.
  20. #17
    Nov 2014
    Colorado
    2,978
    3495
    836
    https://www.clintonaluminum.com/wp-c...ison-Sheet.pdf
    ^^^ differences marked in red...
    Seems (at least according to these guys)… (VISTA).
    MIC6 is a 7000 series alloy.
    (K100 (s) ) seems to be 5083 alloy ? "Modified".
    Flatness
    K100s ---> 5/8” & Up Within .010
    MIC6 : 3/4" & up Within .005”
    Yield Strength
    K100s : 18 ksi
    PIC6 : 15 ksi
    tensile strength
    K100s : 41 ksi
    PIC6: 24 ksi
    Elongation over 2" ?
    K100s: 12 – 15%
    Mic6: 3%
    Micro-Structure :
    K100s: Virtually porosity free
    PIC6: Porous micro structure
    Anodizing
    K100s: Very Good
    PIC6: Special Procedures Req’d….
    __________________________________________________ ____________________________________________
    I can see why your anodizer would want K100...
    Hang on a mo'... flatness ?
    Personally I would try both but I would lean to k100. but Pic6 would probably have a smidge less distortion (as such) not from stress relief but the K100 appears to be more ductile (as far as any cast aluminium alloy can be … which is not very much.). If both carefully machined I think the K100 is a better quality material (zero porosity). 100 to 120 pieces I would think overall consistency of process would be better.
    What ever you do let us know how it goes ?
  21. #18
    Jan 2016
    New Jersey
    230
    78
    103
    I designed a part (~1/4" thick, 18" x 12") that we made in MIC6 at my last employer. Most of the plate was removed to make the part (hence going with cast, bottom surface of the final parts were flat within 0.001"), and it was clear anodized. We never had an issue with anodizing, and in my experience people do refer to it as tooling plate, although I could never get everyone in the room to agree on whether it was "mike" 6 or "mick" 6.
  22. Likes [email protected] liked this post
  23. #19
    Jul 2019
    7
    Hey agreed! the McMaster Carr catalog says the mic6 is a 7000 series, additive zinc.
  24. #20
    Feb 2013
    Idaho
    706
    152
    753
    Quote Originally Posted by Sjzona View Post
    The 7000 alloy designation on mic6 indicates that it was made with 7000 recycled beer cans per 5' by 10' sheet of 1" thick plate. The current designation is actually 7200 series alloy, because beer cans have gotten lighter and now weigh .5714285 ounces and it takes proportionately more cans per sheet. The blotchy anodizing and variability in machining properties result from vendors using multiple brands of beer cans.
    Glad I could help.
  25. Likes gkoenig liked this post
