have you seen the 'version 2' one-lok? I had a half dozen complaints about the original, but it looks like they've solved it with some improvements. Much lighter, can adjust the moving jaw position with one hand.. lots of cool stuffs.
I still have plenty of complaints!
Can't pick the damn thing up from either end for one, which makes it REALLY AWKWARD when you have a subplate that it locates onto... IE the one they make for it. If I were sliding them on I wouldn't care so much but their complementary products should really be operator-tested IMO and this never seemed like a consideration. They're about 80lbs with the hard jaws so it's not trivial, and I don't want to drag the pins across the plate.
The locating pins are
ninety f-ing dollars a pair! This only really applies if you have a subplate though. Still feels gouge-y. Also can't buy them without a wrench now.
Can't turn it on its side.
Can't get two next to each other, especially with the subplate.
Can't buy a split washer from them without buying a full rebuild kit (I understand this one but it still sucks).
Softjaws are expensive ($50 a pair for aluminum and no steel option) - as you know - much cheaper to make your own but they won't hand out the model for that. We said screw it and just buy 10 sets from Monsterjaws and machine the pocket (also thanks again for that model).
There's STILL a LARGE area of the softjaws you can't cut into or you'll hit the dovetail. Which is worse IMO than hitting the bolt heads since replacing bolts is cheap and it'd likely cost an end mill either way.
If I had to start fresh I'd recommend Orange. The CarveSmart system makes way more sense, the vises are more versatile (anyone know if you can set them on the side perhaps?) by making them front, back, or double vises, and I've heard nothing but amazing things about Sol's support.
