Drill leading off
Results 1 to 16 of 16
    Mar 2021
    Ohio
    Default Drill leading off
    Here's my dilemma.
    Drilling a .187 hole 3" deep in 316ss.
    Using a Walter carbide through coolant drill.
    Running in a HAAS Ds30y with high pressure coolant.
    I'm not breaking drills or getting chip weld but my hole keeps leading off center by .006 to .012.
    I'm spot Drilling with a 90° 1/4" carbide going. 025 deep.
    Using a g83 peck cycle withdrawing .5 out of the hole rapid back to .05 from end of last cut.
    Tried running recommend feeds and speeds of 116sf , .0045f
    I've played with peck depth from .05 to .250, feeds from .0025 to .006 and rpm from 1800 to 2500.
    I get the best results around 2300rpm peck of .200 f.003. It holds a few part about. 002 or so off center or better but will then float out then come back.
    I've indicated the drill and spot to .0003 c/l. Ive checked horizontal run out so as to make sure its sitting true to c/l length of the drill.
    I've been machining plastic for the past 15 years. Shop is now venturing into steel and this is my first job.
    Any help is appreciated.
    Sep 2007
    Washington
    5,677
    280
    1895
    Try drilling the first 3/4" or so with a stubby drill, then bring in the long drill.
    Regards.
    Mike
    Sep 2016
    Connecticut
    15
    13
    12
    You should spot the hole with a tool that has a greater drill point angle than the drill itself. This allows the center of the drill to make contact first rather than the od of the flute's.
    Also +1 on the stubby drill for a pilot
    Feb 2001
    Redwood City, CA USA
    5,294
    236
    1157
    Curious why you are pecking if you have high-pressure coolant through the drill.
    Mar 2021
    Ohio
    Mainly from years ago at previous shops just how deep holes were always done. I've been reading other threads about drilling ss. I may give a steady straight pass a shot.
  6. Likes kustomizer liked this post
    Mar 2021
    Ohio
    Thanks , I was pondering this but wasn't sure about chipping edge tips if the hole was slightly smaller.
    Mar 2021
    Ohio
    Ok that makes sense. I'll change tge spot . Tbanks
  9. #8
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    You may consider feeding at 50% upon entry and then going to 100% once the tip is in.....this is useful not only in machining.
  10. #9
    Dec 2020
    Maryland
    242
    140
    48
    Listen, I am not a fan of Titan, but this video he does is pretty informative. You might find this useful.
    Incredible 40XD Deep Hole Drilling in Stainless | Kennametal SGL Drill | Vlog #107 - YouTube
  11. Likes Chris59 liked this post
  12. #10
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    Oh yeah, don’t turn on the thru-tool coolant until the tip is in about 1/2 way.
  13. #11
    Mar 2011
    SWITZERLAND
    1,121
    138
    456
    The stock can work against you. Stainless alloys often bear tensions inside, with round bars you speak of core tension. Just telling
  14. #12
    Feb 2020
    Alabama
    366
    151
    104
    Quote Originally Posted by rklopp View Post
    Right. Also, NEVER peck in stainless with a carbide drill if you can avoid it.
  15. Likes Fancuku liked this post
  16. #13
    Feb 2014
    FL
    4,317
    13571
    5145
    Ok, first question: How much pressure is "high pressure" on a Haas?
    For me, high pressure is 1000PSI, and I wouldn't peck that drill at all (I would consider using a stubby drill for the first inch or so, but we regularly do holes that are .040" or less by 3 to 6 inches long with just one gun drill).
    If high pressure for you is only 250 or 500PSI, then maybe a peck half way through, just to make sure you're evacuating chips well.
    I'm assuming your drill point is 118°, your 90° spot is not doing you any favors, either switch it to a 120° or ditch it completely and just slow your feed for the first .100" or so.
  17. Likes Nerdlinger, cgrim3 liked this post
  18. #14
    Dec 2020
    Maryland
    242
    140
    48
    68machinist70, did everything work out okay for you?
  19. #15
    Aug 2002
    West Unity, Ohio
    27,361
    7762
    9552
    What is the tip angle on your drill?
    Is this maybe a Titex 6685?
    I think that I prepped the start hole for those with a C'drill, followed by a SML Cobalt drill of the same D as the through hole (same tip angle as the Titex tool) and then the long drill.
    My holes were straight, but I was in a lathe and had the benefit of spindle rotation to guide it too, so ....
    I have 1000+ # pump.
    Think Snow Eh!
    Ox
  20. #16
    Aug 2007
    Idaho
    2,475
    1047
    1324
    I think I remember the Haas being 300#?
    could work holding be part of the problem?
