xa-mont
Hot Rolled
- Apr 4, 2014
- Victoria, Australia
Hey guys,
This may be a stupid question, but is there any possible way to drill radial holes off center in a live tooling lathe WITHOUT a Y axis?
The particular part i'm hoping to do this on is 6061 aluminium that i am now getting in a custom extrusion (i used to start with 25x50 rectangle bar and do a ton of milling on it, but with 1000ish a year it was worth getting an extrusion done). With the custom extrusion all that needs to be done now is cut to length, face each end and drill/tap 8 offset m4 holes each side (4 offset one way 4 offset the other way) so i'd love to just bar feed it and have finished parts come out without me touching them.
I was thinking possibly making a custom offset holder might be doable? being only m4 holes there's basically no machining load on them, so regidity is clearly not going to be an issue - i could even run an offset die grinder type tool for the drilling seeing as it's only a 3.3mm hole.
Any thoughts brains trust?
