"Drilled" hole tolerance
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Jun 2002
    U.S.A.
    148
    6
    Default "Drilled" hole tolerance
    Ok.. been an ongoing conflict here at the shop about hole sizes. One of our guys here that inspects parts has a hole tolerance chart he uses for tolerance (attached for reference). Typically if a hole size is stated on the print we use the title block tolerance. Does the tolerance change based on if the hole dimension says "Drill Ø7/32" or if it is called out as Ø7/32.. Keep in mind, tolerance in title block for fractions is ± 1/64"
    Thank you for any information.
    Jun 2019
    862
    381
    954
    It should always be on the print. If it has a tolerance callout for fractions then that is the tolerance. If that is not what they want then they should change the print. IF it's just the inspector wanting this he needs to be informed that parts are made to print, and asked where he got his chart from.
  3. Likes Bobw, JCByrd24 liked this post
    Jun 2012
    Michigan
    14,361
    4894
    5197
    I think that is a good chart, and likely to keep outgoings rejects low,
    If incoming are held/rejected to that you may get an argument.
    The old general rule was.
    General Tolerance 3 Decimal Places-AWS BOS – Welding Classroom
    Feb 2006
    Minneapolis
    242
    13
    35
    Don't know what the standards are but I'd say big difference between telling the machinist to use a 7/32" drill and actually calling out a 7/32" hole
  6. Likes sfriedberg, JCByrd24 liked this post
  7. #5
    Feb 2011
    3,060
    2902
    1457
    Is this an old company? A lot of old prints used to call for fractional hole sizes with no decimal, or the fraction followed by some form of decimal tolerance (Ex: 1/4" +.001/-.0005). When those tolerances were not specified, it was because the tolerance was low, or the machinists were expected to know their fits and be familiar enough with the product to know if a dimension was nominal, under or over sized.
    If his chart is something that the company gave him, it's essentially an extension of the print(s) that everyone should have access to. If it's something HE came up with... he should let it go or share it with you so everyone's on the same page. Even if he sees it that his dimensions are some kind of industry standard, everyone needs access to said standard because there are LOTS of standards out there and they are all "right" for how they are meant to be used. Either way, you can't make a part without all the needed information, and those parts can't be inspected with higher tolerances than the guys are making them to (unless the company just likes to make scrap parts). Inspection is about due diligence, not playing "who's micrometer is more exact."
  8. Likes digger doug, charlie gary liked this post
  9. #6
    Feb 2005
    9,825
    16888
    12045
    A bunch of work I do has the standard tolerance block, and then a little chart that is similar to the one you posted. And it says Holes noted "drill". This isn't rocket science here. If the hole is noted "drill" it falls under the tolerance in the drill tolerance block.. If it is very clearly a hole that will be drilled, but not noted "drill".. It falls under the blanket tolerance.
    Of course, a LOT of prints have a note to use some blah blah blah spec to interpret the drawing.. YOU NEED TO PULL THAT SPEC!!!!!!!!!!! You NEED to READ that SPEC!!!!! The note "Drill" could mean nothing, or it could mean something.
    Of course the obvious answer here is to ask the inspector how he is determining the tolerance, which ones fall under his chart and WHY, and which holes fall under the blanket tolerance.
  10. Likes Jashley73 liked this post
  11. #7
    Jun 2012
    Michigan
    14,361
    4894
    5197
    I liked to hold grinding closer than the print spec. Often the technique would make that as easy as being loose, so little or no time lost.
    Drills with a pre-drill hole usually drill .0002 larger than the micrometer size...as long as the drill or the part does not get hot.
    Drills can have .0003 to .001 back taper per inch so a shortened drill should be measured.
    Drill starting their own hole can cut way big due to an off-center point.
  12. #8
    Jan 2007
    Flushing/Flint, Michigan
    11,089
    663
    8874
    Confused as to how some random chart relates to the customer print.
    Do they have the same home? Is this chart on the print or is it something from who knows where?
    Bob
  13. #9
    Sep 2002
    People's Republic
    6,587
    777
    3905
    Many of my prints specify that a fractional is also 1/64. 1/64 is in the tolerance block, that is what it is.
    Fractions on technical prints [other than tap callouts] mean IDGAF.
    Holding it to closer than the tightest standard tolerance is silly
    Yes it is wise not to run under, but that chart is over tight.
    wasting time fussing, wasting time checking, and oh gawd wasting time rejecting
  14. #10
    Jun 2012
    Michigan
    14,361
    4894
    5197
    Qt [Holding it to closer than the tightest standard tolerance is silly]
    Agree that is the rule of thumb..but knowing a good customer is overly fussy and holding closer than spec will keep that customer happy can be good for the pocket book.
  15. #11
    Jan 2007
    11,089
    663
    8874
    How does one get a hole or in fit under the size of a drill tip actual?
    Done it more than once but confusing.
    Drill a hole and then can not hand fit the same drill through it.
    But,but,but it just went though that hole. Why don't you go in now on the bench?.
    Happy Gilmore (5/10) Best Movie Quote - Are You Too Good For Your Home? (1996) - YouTube
    Poasted here as a confusing question or big smile.
    Darn thing made the hole, it should slide right through. But sometimes it does not.
    Worse yet when using a pin to check and way under.
    Bob
  16. #12
    Sep 2002
    People's Republic
    6,587
    777
    3905
    Bob
    Then it should have been spec'ed differently
    I get a group of parts, the first thing I do is look at them and figure out how to make them not work
    Plenty of times .500 bore and a matching .500 boss both +- .005
    Point is that is bad engineering.
    Make holes over not under, but the listed rules of thumb are not fit for inspection, unless you have a reason to know different
  17. #13
    Sep 2002
    People's Republic
    6,587
    777
    3905
    BTW, what is a 7/32 drilled hole?
    It can be about one thing
    A clearance for a #10 screw
    .218-.016-.005 positional tolerance=.197
    Holding it closer is costing time and money
  18. #14
    Aug 2005
    CT
    8,583
    514
    2334
    All I know is that a non toleranced "drilled hole" cannot always be considered a UOS because they may be controlled by specs of the issuer of the print.
    Take the case of Sikorsky Aircraft specs as an example:
    Part has 2 holes.
    Hole #1 callout: "1/8 drilled hole"
    Hole #2 callout: .125 dia through
    UOS tolerance in title block:
    .xxx - +/-.005
    Fractional - +/-.015
    What do you think your tolerance is for Hole #1 and Hole #2 ?
  19. #15
    Oct 2007
    SPAIN
    5,778
    1620
    883
    What standards you work to, must be defined by the Customer and on the print.
    I had 3x customers all similar, where if the part said "Drill 3.00mm" (for example), it would be -0.01/+.07 tolerance, and if it just stated "3.00", then the general +/-0.1mm would apply.
  20. #16
    Jul 2009
    hope,in
    706
    38
    62
    As for 'Drilled' vs diameter XXX. The company I work for does not like to put machining operations on a print. That limits what manufacturing processes can be used. So, it might limit or exclude suppliers from making parts. Thus, increasing the price of the part. Also, have to watch in dimensioning parts based on production process vs design need. Also, some manufactures have their own 'standards' that might not be provided on the print. I gets fun if they don't provide that information.
    Also, as noted a drill can drill smaller than its diameter. I was told that is impossible. I've done it many of times, though. If the drill is dull, then it will heat up the material. So, the material expands when being drilled. Then it contracts when it cools down.
    I'd add that some parts do require a specific process. It might effect the integrity of the part. Say, milled vs grinding. They would leave a different surface structure. So, the part might crack.
  21. Likes mhajicek, barbter liked this post
  22. #17
    Aug 2002
    West Unity, Ohio
    27,876
    8197
    9880
    Quote Originally Posted by michiganbuck View Post
    The math in that chart is going to make some newbies awfully cornfused....
    Keep your eye on what you are being asked.
    Yeeaaahhhhh......
    Think Snow Eh!
    Ox
  23. #18
    Oct 2007
    SPAIN
    5,778
    1620
    883
    Quote Originally Posted by 75sv1 View Post
    Yes - this is the correct way.
    To be fair to the Customers I was referring to, it was because they all had machine shops (back in the day).
    So the older drawings would state (for instance) Drill, because that would be how the part feature would be produced.
    And a 3.2mm drilled hole would be for an M3 screw, rather than having a 3.5 +/-0.1mm sloppy hole.
    So Nowadays certain sheet metal parts that were CNC'd, would be punched instead of drilled, but the larger nominal size would be required to allow for the larger minus tolerance....
  24. #19
    Aug 2005
    CT
    8,583
    514
    2334
    Perhaps, but you still better hold it to +.003/-.001, or else it's out of tolerance!
  25. #20
    Sep 2002
    People's Republic
    6,587
    777
    3905
    Quote Originally Posted by SeymourDumore View Post
    According to who?
