scarymonkeyman13
- Sep 19, 2018
So I was given an opportunity to start learning cnc on the fly and this forum has been extremely helpful with troubleshooting most things I've encountered but recently I was tasked with making a test fixture that requires drilling 2 0.053" holes 0.068" away from each other in 3/8" GPO-3 board. I will use a 45 chamfer bit to pilot it and the top looks good but the 2nd hole will walk it's way towards the first half the time causing the probes to short together. is there anything I should be doing (drilling straight through vs pecking, slowing feed down more etc.) that I should be doing or is it just the nature of the material that drilling so close, small chunks will tend to break off causing it to walk towards the bottom with such a thin bit?
