plutoniumsalmon
Hot Rolled
- May 27, 2014
- Los Angeles
Hello.
I need to put various through holes into a rod of a572 50 steel. The diameters are from 1/2 to about 3/4 and the depth varies from 1 inch to 2. As my count for live toolholders is tight I was thinking of spiral milling those with a reduced shank .375 5fl endmill from helical HEV-RN-R-50375. Is this a correct way to do it? I can also pocket after plunging or spiral and pocket. Also should I run coolant (no thru spindle for me) or not. I am going to threadmill into these after if that changes anything. So far my speeds and feeds are 4057 rpm at 2.31 in/min down with about a 5 degree spiral
Thank you.
Thank you.
