Drilling on a concave surface
Results 1 to 6 of 6
    Mar 2012
    North Carolina
    368
    1082
    143
    Default Drilling on a concave surface
    I was looking for opinions here on drilling this part. I have a .050-.055 diameter hole that I need to drill on the side of this part. Material is 418 stainless and it will be heat treated to 36rc. Quantity of 40.
    I bought some stubby carbide drills from M.A. Ford that have just enough flute to drill the hole. My question is, should I finish the concave surface first so there is less material to drill through (about .100) or leave a flat for the drill to enter and then finish the surface.
    Sep 2002
    People's Republic
    3,002
    216
    2070
    I appears you are drilling normal to the surface which would make it less likely to walk. If you are concerned use a center drill it should be fine
  3. Likes Red James liked this post
    Feb 2013
    Madison, WI
    968
    1110
    623
    I agree with Gustafson. You should be fine. If it did become an issue you could just program a spotface interpolation to give yourself a flat starting face.
    Jan 2014
    Temecula, Ca
    2,808
    1264
    3647
    I would get it started with a .047 ball em.
    Feb 2014
    Sunny South West Florida, USA
    2,766
    10459
    3193
    The MAFords will drill straight, they do just fine for me. 305 series?
    Mar 2012
    North Carolina
    368
    1082
    143
    Thanks all
