Drilling deep in delrin
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Nov 2018
    Utah
    Default Drilling deep in delrin
    Hello
    I have a job coming up that involves drilling a 7/8 inch hole about 9” deep in delrin on a engine lathe. The last company that did this wound up shattering the delrin while drilling and blowing a hole through the ceiling of his shop. He said that the drill grabs the material too aggressively and gets sucked in. I was not able to get any more details on his set up. While drilling some simple parts on a drill press I had it bite so hard it sucked the part and the vice up off the table. I found that using a spade bit for wood from the hardware store worked very well and did not grab the material like a twist drill did.
    I want to avoid all of these problems. Can you recommend a drill for this 7/8” hole 9” deep? Do I need to re grind the drill? I can drill from both ends but would prefer doing it in one shot.
    May 2011
    New Jersey
    2,280
    201
    1250
    Not sure what the hell that guy was doing but...you can pretty much ram a drill through delrin as fast as you can feed it. Throw some coolant at it and clear the chips here and there. I would say I'm amazed but I'd be lying.
  3. Likes Mtndew, Booze Daily liked this post
    May 2004
    Ridgefield, Wa USA
    609
    201
    74
    Onsrud makes drill bits for plastic I have used them on UHMW they work really good but not 9" deep the flutes only go in about 4" once you pack the bit it is going to stick and pull the part out of the chuck or you will have to peck it to death. I would use the spade bit and a vacuum to suck the chips that works pretty good just break the string every so often.
    Jan 2003
    Canada
    11,273
    5414
    3406
    Don't pilot, always drill to size right away. I use regular HSS twist drills. Probably need a long length one for that.
  6. Likes Bluejeep liked this post
  7. #5
    Aug 2006
    Cape Cod, Ma
    457
    180
    97
    my guess would be they were using a mt shank drill that was not seated well. deep holes in delrin are not a problem just don't drill past the flutes that's a recipe for melt. peck drill and some coolant or I like to liberally brush on some Acculube #10 perfect tap along the drill (which is a great general purpose cutting fluid). even some wax lube along the flutes help to keep the heat down. it's important to keep the heat down as the hole will shrink and grab.
  8. #6
    Jun 2012
    Michigan
    4,730
    4336
    2877
    Quote Originally Posted by CMacine View Post
    That sounds like a massive exaggeration or the other guy was drilling UHMW.
    I've never had a drill grab in Delrin. That is arguably the best material to machine on the planet.
  9. Likes Bobw, Ox, Bill in PA liked this post
  10. #7
    Mar 2009
    5,163
    97
    951
    A Forstner style bit. Probably will need a shank extension.
  11. #8
    Nov 2013
    Utah
    4,640
    1222
    2602
    Hello
    I kid you not, I'm being 100% serious. I think I've heard that story before, and might have worked for that moron. No names. He means well with his warnings, and has decent foresight for potential problems. But he always needs some catastrophic story to back him up, instead of just saying it. Solution has already been stated. To reiterate; coolant, no pilot, don't baby it.
    R
  12. #9
    Nov 2014
    Florida
    3,944
    1590
    1839
    Lets see... I use a lot o "LoL and LMAO", but this has to be the first time in along time it was really true... (:
    edit: was it the little piggy's shop made of straw?
    I'll huff and puff and bllloooowwwww the house down! hahahha
  13. #10
    Dec 2014
    CANADA
    British Columbia
    1,280
    361
    586
    If you're worried about the drill grabbing, brass the drill. Delrin won't care.
    I would not be adverse to drilling it half and half undersized and hitting it with a boring bar to pretty it up.
  14. Likes aj liked this post
  15. #11
    Feb 2005
    9,046
    13904
    10718
    Quote Originally Posted by Mtndew View Post
    Arguably?? Its a fact!!! All machined parts should be made from Delrin (or at least all
    the machined parts I have to make)..
    I've never had a drill grab in Delrin either. Its really mild mannered.. Its hard enough that
    you can hold it, its soft enough to cut easy, but hard enough that its not gummy like Teflon or
    UHMW . I've personally never experienced the grabbing and pulling with delrin that some
    of the other softer plastics are famous for.
    I was trying to open up a 5/16 hole to 3/8 the other day in Nylon, with a hand drill..
    Damn drill just screwed itself into the nylon.. Like a self tapping drill/screw?
    Delrin would never do that, its too well mannered.
  16. #12
    Nov 2013
    Utah
    4,640
    1222
    2602
    Aside from just thinking about the process and facts--a part that is 9" long in a manual lathe chuck, with a 7/8" Drill inside of it, suddenly pulled out of the chuck, somehow escaped having a big ass Drill in it----THEN managed to fly upward with enough force to break a hole in the roof!!!!! Good God, WTF is going on?
    Meanwhile, back in reality-assuming the Drill did bite too deep, the part spun in the chuck. What else could realistically happen? The MT slipped maybe, but the fucking thing didn't drill itself a hole deep enough to let the whole Drill go.
    Even if the part somehow got away, if it had that much force it would break. Delrin isn't great for hard impact.
  17. #13
    Mar 2011
    Geneva Illinois USA
    6,216
    2668
    2411
    You want to make sure the margins aren't worn.
    Tom
  18. #14
    Sep 2010
    Vancouver Canada
    933
    685
    334
    Where I come from (research machine shops established by post-war European emigres where lightly used tools can hang around for a REALLY long time) they'd always have two sets of HSS drills, one for aluminum and steel with the normal cutting angle and one for brass and plastic with the cutting angle ground back to 90 degrees or so. I started a thread recently about the history of Delrin in prototyping because in physics anyway, Nylon and teflon were preferred for vacuum outgassing reasons so I'm not sure what the official old European guy view on Delrin is. So I would ask, would it still be better to use less acute cutting angle on Delrin if you happened to have such a drill, or is Delrin so good it really doesn't matter?
  19. #15
    Sep 2005
    Oakland, CA
    2,495
    299
    672
    If grabbing its an issue, just flatten the lips of the drill slightly and it won't dig in or grab. if you are getting a formaldehyde smell during machining, you are melting the resin- slow things down a bit and life will be good.
  20. #16
    Nov 2013
    Utah
    4,640
    1222
    2602
    Call me crazy Dan. I've heard it before about the smell of formaldehyde, in relation to melting Delrin/Acetal. I have no idea what formaldehyde smells like! I don't hang out in the same places some as you guys, I guess. I'm trying to grasp why or under what circumstances, you people are smelling embalming fluid.
    R
    "This Chloraphorm smells funny to me, here you smell it and see if you think it smells weird too"
  21. #17
    Feb 2014
    Sunny South West Florida, USA
    2,881
    10700
    3274
    R
    I've smelled the formaldehyde (You never dissected anything in school, Rob? We dissected cats for my AP Biology class my freshman year... They hung around for about 2 weeks before we finished... Yeah, I'll never forget what formaldehyde smells like...)... I also think it vaguely smells like the Crayola brand paints we used in art class when I was in elementary school.... Not sure why... Smell is a funny thing, it's really good at triggering long dormant memories...
  22. #18
    Nov 2013
    Utah
    4,640
    1222
    2602
    Naw, I dropped out in the 6th grade, once I finished Elementary school.
    R
  23. Likes TeachMePlease, Mtndew liked this post
  24. #19
    Aug 2002
    West Unity, Ohio
    25,414
    5670
    8091
    Hello
    Just in case of grabbing in a quill app, just keep some tension of the quill brake.
    This is the "CNC" board tho.
    Think Snow Eh!
    Ox
  25. #20
    Jan 2003
    Canada
    11,273
    5414
    3406
    I should add it can grab when it punches through the other side if feeding heavy, mostly with bigger drills. Moderate feed is usually good, too heavy can fracture it a little. PVC does that too.
  26. Likes Ox, litlerob1 liked this post
