fultorn
- Apr 17, 2014
- Montgomery, AL
This only started happening about 2 weeks after changing the spindle motor,
after the machine has been turned off over night. in the morning they will turn the spindle on and warm up the machine. when they go to do the first tool change Alarm 252 comes on (ATC spindle 252)
the manual says to check on Diagnosis bit 531, if bit 6 is 1 then there is a deviation in magazine index.
if bit 2 is 1 then there is a deviation in spindle movement. this is the Bits that i got: 01100100,
6 and 2 are on! after i do a turret restoration after the alarm it will make tool changes fine and sometimes in the mornings it wont even alarm out!
i called Methods Machine and spoke to Michael said that this is strange and would have to have a tech sent out to take a look at it. which i really dont want to do.,.
any leads on this or advice would be appreciated.
