Dynapath 40 Control Issue (E-Stop)
Results 1 to 8 of 8
    Apr 2021
    Iowa
    11
    Default Dynapath 40 Control Issue (E-Stop)
    Greetings All,
    I have a Tree Journeyman 250 with a Dynapath 40 controller on it. When it boots up, I release the estop to proceed through the axis homing/referencing process but it keeps throwing an error code that the estop has not cleared, which is not allowing the motors to kick online. Does anyone have thoughts on how I could bypass this switch or figure out whats going on?
    Apr 2018
    9,233
    4481
    Quote Originally Posted by mhansen View Post
    E-stop is a normally-closed circuit that has to be complete for the startup to proceed. Any broken wire, open switch, bad contact or whatever will keep it from operating.
    This is a good thing. Machines are dangerous, an uncontrolled axis runaway will happily crush your hand, arm, leg, head, whatever. You don't want to bypass an e-stop circuit ever. You may need it some day.
    Find what's wrong and fix it.
  3. Likes Greg White liked this post
    May 2010
    St-Colomban,Que. Canada
    29
    5
    Make sure your off and away from the limit switches before homing. I need to take off the e stop and then press the reset button a couple of times at startup on my 40 50 60 controller to get it going.
    Apr 2021
    Iowa
    11
    Quote Originally Posted by NASTYZEN View Post
    is there a limit switch in the Z? I dont see the machine is against the x or the y limits?
    May 2010
    29
    5
    Mine does. All axis must have a lmit switch so as not to bottom the ball screws.
    Apr 2018
    9,233
    4481
    And usually a normally-closed uh-oh switch, in case everythign else fails and the slide goes past where it's supposed to.
    Feb 2014
    Southern Illinois University
    104
    32
    Does the machine start? The green light on the machine start button blink, and then go solid when you press it? Any lights blinking on the control?
  9. #8
    Oct 2006
    MI
    80
    73
    13
    Do you have an Update?
