BluishInventor
- Jul 7, 2020
We have a Haas ST30Y and my experience with lathes isn't much better than mediocre. I've made and programmed some cools stuff, but now I have a part where I need every bit of accuracy I can get. While the tool setter can set X and Z, what are some proper methods for dialing in Y for live tools?
I've tried loading up my coax in the spindle and dialing in the shank of the tool or the collet seat of the live tool block. But it still seems off. In some cases couple thousandths. I've also used a test indicator on a mag base, but the droop I get from gravity seems to affect my results.
What methods do you use to dial in your live tools(or static for that matter) to be absolutely on the money?
