Hi, this might be a stupid question but I'm trying to take on a job that might just be too big for my lathe, I already removed the tool changer and am running a tool holder I made for an 1/2" insert, I have .1" clearance between the part and the max X travel on the lathe, so I'm a bit limited on strategies. I need to cut the center section but am running into chatter so bad it's moving the part around, or breaking inserts, is there a feed/speed recommendation for this? I am also running into stopping the spindle if I enter the part or feed too aggressively... would really like to be able to make these parts, but I need to know if I should call it and move on. I am also considering using a smaller 6mm round insert, but I feel like having such a skinny tool holder would make the chatter worse....
