Recently pickup up the lathe and started having issues a week after powering it up. I switch the machine on and the controller doesn't not come on at the first try. Sometimes it does the second time or the third or fourth but it always does eventually. Once on it runs great less than 3 times now while just sitting idle the screen goes blank and turns everything but the fans off. Turning it off then back on fixes the issue.
Once its warmed up I can turn it off and on without issues. Temps are 60ish when I have issues getting it to come on.
Using a rotary phase 10hp to a setup transformer. The volts going in is suppose to be 380v but Im at 401v, plan to knock that down soon. Line to line voltage is within 3%.
The machine is in surprisingly good condition for its age. Both batteries are within spec on voltage. I have a feeling its something simple but not sure. I was told that this is a new thing and the previous owner never had this issue.
Any ideas or guesses is very much welcome right now.
