Emcoturn 120 problem
Likes Likes:  0
Results 1 to 2 of 2
    Nov 2014
    BELGIUM
    Default Emcoturn 120 problem
    Hello everyone ,
    When I turned my Emcoturn 120 controller on this week I heard a sissing sound coming from inside the emcotronic tm 02. I immediately noticed a burned smell so I removed the back cover from the controller.
    I saw that there was a small resistant that got burned on a circuit board so I removed the board and brought it to a electronic shop to get the circuit board cleaned and fixed.(They replaced a bunch of other componends too)
    When I put everything together and turn the machine on I always get an alarm that says; coolant pump overload ( alarm 080)...and even when the pump is not activated.
    The machine has no thermal protection on the pump that can be switched back so I guess that the problem is still in the circuit board.
    So maybe there are people here that own a emcoturn 120 and experienced the same problem?
    Thanks , Jury
    Jun 2015
    Colorado
    599
    1209
    253
    Have you checked that the pump is operational? Check the motor for shorts.
