03-30-2016, 12:09 PM #1
Endless loop: Main program terminated by M99
I'm adding new features to the rs274ngc G-code interpreter to make it more compatible with Fanuc and other controllers. One such feature is numbering the main or sub-program with e.g. O1, and adding the M98 and M99 codes. (By contrast, rs274ngc-flavored code allows no main program number, and sub-programs are defined with O1 sub...O1 endsub and called with O1 call.)
Smid 3rd Ed. offhandedly mentions on p. 384, "Subprogram Functions" section, para. 2:
Although M99 is mostly used to end a subprogram, it may also
be rarely used in the main program, replacing the M30 function.
In this case, the program will run 'forever', or until the _Reset_
key is pressed.
My question for you experienced machine operators out there is, how is a main program distinguished from a subprogram? Consider the following example:
Code:O1 (Main program) (print, Main program 1: calling subprogram 2) M98 P2 M99 O2 (Subprogram) (print, Subprogram 2: returning to main program 1) M99 %
Most g-code dialects, when faced with an M99 and no M98 having
called will simply start executing the very first line of g-code
at the top of the program again.
I can see two ways to handle this:
1) Simply pick the first numbered program (O1 in the above example) as the main program. The Fanuc examples all seem to have subprograms following the main program. However, I don't know if this is a requirement, and the rs274ngc case isn't instructive, since O sub-style subroutines may come either before or (now that I unbroke a several-year-old regression) after.
2) Prohibit M99 terminating numbered programs. The controller would raise an error for the above example, and the example could be fixed by removing the O1 block.
Any suggestions?
03-30-2016, 12:44 PM #2
Fanuc control does not differentiate between main program and subprogram. All programs are registered in the same manner, with different program numbers. Any program may call any other program, provided it is logically correct. Nesting up to four levels is also allowed.
Normally, main programs end with M30/M02, and subprograms/macros with M99.
01-08-2021, 04:44 AM #3
Hi all,
I found a solution to avoid that thing.
My O0100 is a macro to reset the machine status.
It can be called in MDI and as MAIN programm to.
the macro look like that:
O0100
move safely
#100=99(DEFAULT M99 END CODE)
IF[#4000EQ100]THEN#100=30(USE M30 INSTEAD OF M99 IF O0100 SELECTED AS MAIN)
M[#100]
I hope that can helps
