snapatap
- Apr 24, 2013
- south australia
Has anybody had anything to do with manual universal milling heads made by "neo precision tech" fitted to the Eumach FBE series mills? The tool changer cylinder has been leaking oil but i had to keep the mill going on the job its on. today the tools started sticking in the spindle, so i pulled the cylinder off to reaseal it, easy enough. I would like to pull the drawbar out to inspect it, but i'm not sure about re setting the preload on the belleville washers if i do, can i just do the nut up to the same spot or would there be a spec to torque it up to? or should i just leave it alone?
