F&S for 3/32 drill in 304 stainless to avoid work hardening?
Likes Likes:  0
Results 1 to 3 of 3
    May 2006
    Illinois
    247
    99
    48
    Default F&S for 3/32 drill in 304 stainless to avoid work hardening?
    I need to drill a series of 3/32 holes in 304 stainless to a depth of 1 inch. I'm using solid carbide bits and flood cooling. First attempt I ran at 6040 rpm, plunge @ 8in/min, and pecked 0.060. (Full retract.) Bit broke about 1/2 way in.
    I'm assuming I need to slow the spindle down quite a bit. What would be a safe starting feed and speed to avoid work hardening? Also, what peck depth would you recommend?
    Thanks.
    gm
    Sep 2007
    Northern VA
    490
    6
    58
    Skip the carbide unless you have thru-spindle coolant. Spot with 140° carbide spot drill (Lakeshore Carbide). YG1 TiN Cobalt 130°Point Parabolic Flute Drill. 1500 RPM, 2.0 IPM, peck @ 0.060" like you're doing.
    May 2006
    Illinois
    247
    99
    48
    Thanks! I'll give it a shot.
    gm
