Face to length bar stock
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jan 2020
    Colorado
    Default Face to length bar stock
    Hello, I need some help learning, or get some pointers on how to face both sides of sawed bar stock, while getting it to a specific length (12.635in to 12.539in). Anything will be helpful, sorry if this is posted in the wrong catagory.
    Sep 2006
    SW Wisconsin
    541
    30
    140
    Quote Originally Posted by bowbrow View Post
    For that kind of tolerance a tape measure is good to go.
    What machines do you have?
    Ed.
    Jul 2006
    Hillsboro, New Hampshire
    8,425
    2015
    5869
    Start by telling us what machines and tooling you have access to, and accuracy requirements besides OAL (squareness, etc.). How thick and wide is the material, not to mention what is it (Al, steel?). Rectangular? Round? And how much experience do you have setting up the machines?
    That's a pretty damn open length tolerance...
    Sep 2010
    Oklahoma City, OK
    4,693
    807
    1937
    Saw off, skin cut 1st face, measure, skin cut 2nd face, measure, adjust, recut 2nd face to desired length.
    There's faster ways, but that's the basic outline.
    Jan 2019
    Arizona
    816
    76
    281
    Make or buy an extension for a collet stop if yours unsing a collet, if your using a chuck, take out the chip shield in the center(three bolts) make an Identical one that has a deep counter bore in it with a 1/2-20 threaded bolt that you can adjust. mack sure if you make a long one that you make it close to the draw tube dia so you dont get vibration. screw that on in place of the dust cover and your golden
    Dec 2012
    Se Ma USA
    1,643
    126
    906
    Stick it in the chuck.
    Face the end.
    Transfer to sub spindle, may need to swallow twice because of length.
    Face other end.
    To be sure you start with an over length part and first attempt you program the part a bit long. Measure actual length against program length and adjust from there.
    Assuming you have a sub spindle lathe like the rest of us.
  7. Likes Ox, aj liked this post
    May 2019
    653
    187
    284
    Do we even know if this is turning work? With those tolerances a bandsaw might be the final op. WAY too many details left out.
  9. #8
    Apr 2018
    3,797
    1713
    You guys don't have the machine disease bad enough. I'd be looking for a double-headed Cincinnati production mill. Drop the parts on v-blocks and run em between the cutters. Chunk chunk chunk done.
    If you can find one, I bet those things don't bring five hundred bucks.
  10. #9
    Aug 2002
    West Unity, Ohio
    25,703
    6008
    8293
    Quote Originally Posted by EmanuelGoldstein View Post
    Last I knew - they fetched real $.
    Think Snow Eh!
    Ox
  11. #10
    Oct 2005
    16,614
    I did a job like this (but to within .005 on the length) years ago on the Oac chucker.
    Simply placed the barstock in the chuck to a hard stop (stepped jaw on this short piece).
    Face, and chamfer, drill and bore.
    Stop cycle, remove part, toss a simple H&G washer into chuck to space part out a pre-determined distance.
    Put part back in chuck (other end sticking out) complete cycle with another face & chamfer.
  12. #11
    Nov 2013
    Utah
    4,723
    1249
    2640
    I like to Face one end on all 5,000,000,000,000 pieces. Then set some sort of stop up to do the other end.
    Or use a robot gantry, and face to face turning centers with 8 spindles each. Since we have no idea what have.
    R
  13. #12
    May 2019
    653
    187
    284
    R
    With numbers like that I would likely sub it out for a penny less per unit and retire off all the pennies.
  14. #13
    Jan 2017
    Oregon
    3,137
    629
    2169
    I have adjustable stops that go down the drawtube for long pieces, and a 16C collet stop for short pieces.
    G54 is the first end, leaves the part long. G55 is the second end, face to finish length. M00 in the middle of the program to swap ends.
    The only caveat is that if the material varies in diameter, it affects the length when using the 3-jaw, since the stop is moving with the drawtube. Normally not an issue and it's not hard to hold .002" in length as long as I am checking the diameters.
  15. Likes digger doug, Fancuku liked this post
  16. #14
    Apr 2005
    Beaverdam, Virginia
    7,910
    854
    3773
    What is the type and diameter of material? How many pieces? What machines do you have at your disposal? We cannot give proper help without more information.
  17. #15
    Apr 2005
    Beaverdam, Virginia
    7,910
    854
    3773
    Quote Originally Posted by atex57 View Post
    Ed.
    If he was facing cast bronze in rounds using a lathe with a collet closer, a tape measure might not be good enough. I have seen round bars of that crap that were .050 out of round and had .100 taper from one end to the other in sizes less than 1".
  18. #16
    Jun 2012
    Idaho
    3,166
    1749
    2064
    stick in a mill vise.That way you can mount a stop to the bed .Faster than a lathe if diameter not too big.Course we don't know what you are doing exactly from your vague information in the wrong section of the Forum.
  19. #17
    Apr 2018
    3,797
    1713
    I guess the supply dried up ? I miss Stan Salles ... and Coastal ! Both those guys had old junk for good prices.
    You could do it on a cheap horizontal with a multi-v-block setup .... have to swing them around once tho. The little K&T's don't take much space.
  20. #18
    Aug 2002
    West Unity, Ohio
    25,703
    6008
    8293
    Search Results for "duplex" - MachineTools.com
    Think Snow Eh!
    Ox
  21. #19
    Apr 2018
    3,797
    1713
    Speaking of not putting prices on things ...
    If those are at that Great American place, I bet they are pricy ! Those boys sure are proud of their stuff ...
    But that 7 axis spar mill, Ox .... that's right up your alley ! You could set every fixture you own on it and just drive the gantry back and forth to go from job to job
    edit: I blew the photo up and see Yoder. Those guys seem to be okay. But this one is a bit small, he needs more air between the cutters.
    I bet you could do a cheap horizontal though with two BIG cutters spaced 25" apart on an arbor, then drive the parts between. Make some aluminum V fixtures, stack them six deep and grab the feed handle ? Should be into it less than a thousand bucks and it would be very automatic, even the floor sweeper could change parts and run it ?
  22. #20
    Feb 2007
    Aberdeen, UK
    3,726
    1295
    1468
    Big horizontal mills are like hens teeth here. It seems like they should be plentiful and bring scrap money, and I would have one in a heartbeat for this and a handful of other things that they are really good at.
    I imagine they were plentiful and brought scrap money a couple of decades ago, and they all ended up in the scrapyard.
    Duplex mills are even rarer it seems. I think maybe once or twice in all the time I've been in this trade I've seen one of those pop up for sale.
  23. Likes Ox liked this post
