I am going to give my first attempt at cutting kovar a go. I believe I have my feeds and speeds dialed in for using an end mill so I am going try that first. As for face milling, my question is, what are some good recommendations for SFM and chip load?
Milling Insert SEHW1204AFTN ACK300 MariTool
Square Insert Shell Mill - Face Mill 45deg X 2.48 dia MariTool
Those are the inserts/ face mill body I am using.
I typically run stainless with this cutter at 500 SFM and about .003 chip load for a nice finish.
I only need to dust off about .005 off of this. I am assuming I will be running coolant. (qualichem 250c is what I have)
Plates are .125" thick and I'm going to take them to .120". Using the super glue and tape method to hold down the plates (I have my method for that dialed in) I have a cat40 big plus spindle with a dual contact arbor for the shell mill also.
Any help would be appreciated. Never cut any material like this before.
