Faceting/waves in internal bore
Likes Likes:  0
Results 1 to 8 of 8
    Aug 2018
    57
    7
    12
    Default Faceting/waves in internal bore
    I am trying to machine an elliptical bore in annealed PH 17-4 round stock (see photo below) with a Haas TM-1P. The part is held in custom aluminum soft jaws. The bore is around 1.5" diameter and I am using a 3/8" 4 flute AlTiN Kyocera end mill. I've roughed most of the stock with a radius endmill, leaving around 8 mils of radial and axial stock, then I come in for the finish pass with the square end mill.
    The central rod shown is cut in the same pass with the same tool and comes out with a very nice surface finish. However, as you can see in the picture, the outer bore is faceted/wavy. I have tried a bunch of different things to improve the surface finish - faster and slower feeds, multiple depths, spring passes, climb and conventional milling, and even different toolpath smoothing options. None of these changes did anything - the patterns is very consistent.
    Any ideas?
    Thanks!
    Ben
    Aug 2018
    57
    7
    12
    Sep 2017
    Wisconsin
    592
    80
    293
    Have you tried a profile ramping operation? What kind of SFM and feed per tooth?
    Jan 2015
    Missouri
    998
    210
    603
    Is this from a cam system?
    Jan 2015
    Missouri
    998
    210
    603
    Are you cutting with a arc move or is it line segments
    Aug 2018
    57
    7
    12
    I am using a 2D contour toolpath. It looks like it is a bunch of straight line segments despite smoothing being in. I am trying to get it to output arcs but there seems to be some interactions I don't understand between tolerances, smoothing, and the options in the post code, but I bet this is the problem. Thanks!
    (2D Contour6)
    N34445 G1 X-0.0406 Y0.4331 F400.
    N34450 G0 Z0.6
    N34455 Z-0.2195
    N34460 G1 Z-0.9975 F5.322
    N34465 G3 Y0.4706 Z-1.035 J0.0375 K0.
    N34470 G1 Y0.4806 F15.
    N34475 G17 G2 X-0.0031 Y0.5181 I0.0375 J0.
    N34480 G1 X0.0186
    N34485 X0.0558 Y0.5159
    N34490 X0.0926 Y0.5115
    N34495 X0.1291 Y0.5048
    N34500 X0.165 Y0.4961
    N34505 X0.2001 Y0.4852
    N34510 X0.2343 Y0.4722
    Aug 2018
    57
    7
    12
    That fixed it - smoothing had to be set to 3 times the tolerance in HSM or it wouldn't smooth and just used line segments.
    Sep 2017
    Wisconsin
    592
    80
    293
    I fight with that a lot - that is why I asked about the helical boring cycle since for some reason HSM seems to like to output those in arcs without worrying about futzing with smoothing.
