Fadal 15XT Z-Overload on Peck Drilling
Results 1 to 6 of 6
    Jul 2014
    Ontario, Canada
    1,096
    759
    704
    Default Fadal 15XT Z-Overload on Peck Drilling
    Chip-break cycle rather, 27/64 drill in D2 plate 1” deep. The machine started doing freaky things a couple of days ago. The cycle will begin at the first hole and peck 0.100” deep, retract 0.100” to break chip, peck to 0.200” etc. On the third/fourth peck, Z will no longer retract and the feed will decrease (but continue) while the Z servo load increases significantly.
    The creeping up of the Z servo load is shown in the attached photo. Machine will E-stop and throw a Z Axis Overload Alarm when the value at 7022 in photo gets to 9xxx. This is the axis load, correct?
    Further, though the Z depth is programmed for -1.200”, the actual depth drilled is 0.400” or so, when it doesn’t alarm out. Control states the 1.200” depth has been reached when you watch it.
    1. Way lube operational
    2. Z slides oiled manually, no mechanical resistance
    3. Drilling via MPG works as intended, correct Z depth, no increased axis load
    4. Peck drill cycle vs. drilling with constant feed causes same alarm condition
    5. Cycling on/off, tried it after sitting overnight = no change
    6. Drill is not moving/slipping in chuck. Confirmed tool height.
    Z axis servo amp? I’m at a loss. Thank you all.
    Feb 2005
    9,654
    16349
    11761
    That number is the following error.
    Have you tried running the drill cycle in air?
    If you long hand a drilling cycle, does it do the same thing?
    Jul 2018
    Massachusetts
    20
    Sounds like a servo needs replacing. How's the sound? Possible the motor is on the way out?
    Jan 2019
    Arizona
    1,278
    112
    518
    It has nothing to do with the peck drilling.
    its your z axis. motor, ball screw turcite , oil issue on z axis or counter weight system) maybe electrical
    try these things 1st to eliminate the the problem
    run the program at 25% rapid and 50% rapid.
    run the program with the Z0 4"-6" higher ( this will tell if you have a mechanical bind at some location or counter weight chains dragging)
    Quote Originally Posted by RC Mech View Post
    Jul 2014
    Ontario, Canada
    1,096
    759
    704
    Moved tool offset +4.0”, cut air. No problem, 30-32 following error. Kept Z height at part zero, moved 12” in X to clear part/vise and cut air, 30-32 following error.
    Programmed for 22 SFM rather than 200 SFM for HSS in D2. No problems. One dope-slap for me.
    Thanks everyone.
    Feb 2005
    9,654
    16349
    11761
    Thanks everyone.
    Broaching the hole didn't work? I'm really surprised it didn't alarm out.
  7. Likes RC Mech liked this post
