Fadal 4th axis brake question
Likes Likes:  0
Results 1 to 5 of 5
    Dec 2015
    Connecticut
    1,387
    32
    469
    Default Fadal 4th axis brake question
    So I added a VH-65 to my VMC 20. I ended up having to add the inhibit board that turns the servo off when the brake is on.
    So my question is: I assume the brake should be on when machining? The brake can be turned on/off with M60/61
    I believe there is an Auto brake parameter that will turn the brake on after 75 seconds. Seems like you would want the brake on right before machining.
    I was going to have the post processor modified to add the M codes before and after any A axis moves ie
    M61 A90 M60
    Any reason why I shouldn’t do this?
    Jun 2018
    Idaho
    179
    74
    47
    I don't think you need the M61's. We just use M60 after every A-Axis move. The brake automatically releases when the control reads the next A-Axis move.
    But yeah we use M60 after every A-Axis move. Never used M61 within the program and never had any problems.
    Dec 2015
    Connecticut
    1,387
    32
    469
    Ok thanks, the guy that modded my post added the M61 , can’t hurt I suppose.
    Thanks for the reply
    Nov 2019
    Missouri
    63
    59
    8
    FWIW,We have had ours for a long, time. The only time we use m60 is for milling. It does fine for drilling and tapping just using A.
    Dec 2015
    Connecticut
    1,387
    32
    469
    Quote Originally Posted by mr.greenman View Post
    Good to know, thx. I guess it makes sense with no side loads
