Fadal alarm at 99,000 lines of code - N word exceeds 99,999
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Sep 2018
    Massachusetts
    40
    56
    Default Fadal alarm at 99,000 lines of code - N word exceeds 99,999
    We are drip feeding from a calmotion usb to our fadal and get an alarm - N word exceeds 99,999. Is there anyway around this? I am thinking about editing the post to increment line numbers by .1 instead of 1 (ex. N1.1 N1.2 N1.3 etc.) is this possible? Any other suggestions or recommendations? This machine has a -4 processor if that makes a difference. Breaking down programs and babysitting is a huge PITA. We typically program in Fusion360 but also have Mastercam available. I find it hard to believe the machine cant handle more than 99,999 lines especially when drip feeding but then again, its a fadal...
    Jun 2006
    Hawthorne, CA USA
    199
    41
    67
    You can increment by .1 etc or use format 1 (Fanuc style) I believe does not require line numbers.
  3. Likes Ewindward liked this post
    Sep 2018
    Massachusetts
    40
    56
    thanks for the info on the .1 line numbers I am going to give that a try. I run the machine fanuc style but now that you say that, I have never tried running a program without line numbers, I will definitely try that as well.
    Jan 2015
    Missouri
    1,058
    212
    660
    I run format 2 Iíve ran lots of programs no telling how big Iíve never seen anything come up must be a setting somewhere
    Don
    Sep 2018
    Massachusetts
    40
    56
    Quote Originally Posted by D Nelson View Post
    Don
    Are you drip feeding? I dont have a manual for the machine but maybe i should find one online and see if its a parameter.
    Jan 2015
    Missouri
    1,058
    212
    660
    Cd,10 enter then type DNCX,file name dotNCthen plus sign
    Hope that helps from a calmotiin box
    Don
  8. Likes Ewindward liked this post
  9. #7
    Sep 2018
    Massachusetts
    40
    56
    Yeah thats what we are using as well, same format. Very interesting you dont get the same alarm. If you dont mind me asking what model fadal is it?
  10. #8
    Jan 2015
    Missouri
    1,058
    212
    660
    99 40/20a
  11. #9
    Jan 2015
    Missouri
    1,058
    212
    660
    Call calmotion ask for glen decausin his dad was part of Fadal he definitely knows his shit about a fadal he can tell you the truth about it
    Don
  12. Likes Ewindward liked this post
  13. #10
    Sep 2018
    Massachusetts
    40
    56
    Awesome will do. Thanks guys.
  14. #11
    Jun 2019
    Maryland
    377
    57
    the older haas controls stop at N100000 . just remove your N 's and it should run fine.
  15. #12
    Jan 2015
    Missouri
    1,058
    212
    660
    Itís not the control Iíve surfaced for 17 hours straight drip feeding itís never gave a alarm for me
    Don
  16. Likes macds liked this post
  17. #13
    May 2017
    Minnesota
    1,128
    1400
    772
    I only use line numbers at toolchanges. With 10,000+ line computer generated programs you're not going to be restarting in the middle of a tool anyway. In Mastercam you can click "force toolchange" if you want to separate a cut for dialing in or checking the cutter. I have a program close to 100,000 lines that goes up to N29.
  18. Likes Booze Daily liked this post
  19. #14
    Jul 2008
    Milverton, Ontario, Canada
    660
    187
    292
    Don
    Yup, literally just got done a surfacing path that was a touch over 56 hours.
    I have my post restart line numbering at 50000.
    Figure, IF I have a problem, I can find which line inside of those 50K I need to restart at.
    Biggest issue I have is with NCFadal. If I dont move the dnc window once inside every 24hr block, the program itself crashes and leaves the machine hanging at the last line in the buffer.
    Might looks into an alternative, but Ive been very happy with ncfadal aside from that.
    In the 1000's of drip feed hours, not one oopsie move.
  20. #15
    Jan 2019
    SWEDEN
    196
    57
    24
    What mhajicek said, I don't understand why you need line numbers. Yes I'll have them at tool changes and no more. When I write macros I always optimize for speed by removing all redundant code bits. Maybe I'm missing something.
  21. #16
    Jul 2014
    Ontario, Canada
    1,039
    745
    676
    Our Fadal runs Format 2 and it wonít DNC a file from a USB (Calmotion USB reader) unless there are line numbers. What is the trick?
  22. #17
    Jan 2019
    SWEDEN
    196
    57
    24
    Quote Originally Posted by RC Mech View Post
    Our Fadal runs Format 2 and it won’t DNC a file from a USB (Calmotion USB reader) unless there are line numbers. What is the trick?
    None, I had no idea of that, please ignore my ignorance
  23. #18
    Sep 2008
    1,752
    1165
    1011
    Quote Originally Posted by in2glamisgirl View Post
    Format 2 is Fanuc style.
  24. Likes RC Mech liked this post
  25. #19
    Sep 2008
    1,752
    1165
    1011
    Quote Originally Posted by macds View Post
    For some reason I couldn't get NCFadal to drip feed.
    OneDNC (free) from OneCNC worked ok for drip feeding, so that's what I use.
  26. #20
    Jan 2011
    Fairfield, PA
    374
    180
    175
    Not the same control, but my Fagor has a 9,999 line number limit. Whe I drip feed, I have the post assign the same number to each line, N1. The control does not care.
    Bill
