I know there's tons of threads on this subject and I've searched and read as many as I could find, but haven't really found an answer to this. Interested in thoughts on what could be going on here.
Between my business partner and I, we have three Fadals: a very old (but very tight) VMC40, a 1999 4020, and a 2000 4020.
Last fall I pried open my wallet and got a tool holder test gauge (CAT40)
The VMC40 got an all-new spindle with drawbar a few years ago. It measures north of 1600lbs of pressure.
The 1999 4020 was showing about 400lbs. We replaced the bellevilles (I don't know the count) and it came up to about 1500lbs.
The 2000 4020 was showing about 600lbs. I replaced the bellevilles and it only came up to about 850lbs. This has me scratching my head a bit.
Here's the details. This is the first time that machine has ever got the bellevilles replaced. The spring pocket is the 4.627" depth, which calls for 44 washers. I removed 41 intact washers and enough fragments to account for the other three. Not that it should matter (I don't think) but this is a 28" Z machine, the only one of the bunch.
I replaced the floater, even though there really wasn't anything wrong with the old one. I couldn't see anything really wrong with the drawbar either, other than some wear on the portion of the shaft that sticks up through the springs, apparently from the springs rubbing on it. The tool retention end of it looked fine and none of the ball bearings fell through the holes or anything like that. I used anti-seize to hold all the balls in place for the installation of both the floater and drawbar.
After installing 44 brand spanky new washers, all gooped up with anti-seize, I got the rather disappointing 850lbs result. It actually started out about 900, but it seems like they lose 50lbs rather quickly as the springs settle in.
I then added two washers, bringing it up to 46. It wasn't particularly difficult to compress them to get the keepers on. I got about 1050lbs after settling.
The washers come in sets of 47, and I didn't really want to put an odd number in there because you need an even number to orient them the way the drawing shows (cup down on the bottom washer, cup up on the top washer). So I ordered in another full set.
I went ahead and pulled out the 46 brand new washers and tossed in 46 brand newer washers. Same result, there wasn't a dime's worth of difference.
Them I added two more. I'm up to 48 now, which is getting close to the limit of what could go in there and still get the keepers on. The stack sticks well out the top of the spring pocket prior to compressing them all. I dunno, maybe I could get one more in there, but I highly doubt I could add two. I got 1250lbs, settling to 1200.
Which I suppose is OK. I mean, it's working, and it's twice as much as I had before I started this little exercise. But I can't figure out why this machine shows so much less pressure than the other machines. It's a mystery to me.
More details: Same tester was used on all three machines. Also I loaned the tester to another local shop and after changing the washers on his 4020 he reported north of 1500lbs. Also, I measured the dimensions of the original springs and the new replacements and they appear identical in all respects. Same thickness, same diameter, same height.
Any ideas? Is there something wrong with the drawbar itself?
