Fadal board pictures, please tell me if they are compatible
Results 1 to 14 of 14
    Dec 2015
    Connecticut
    1,095
    26
    360
    Default Fadal board pictures, please tell me if they are compatible
    In my on-going saga of adding rigid tapping to my 93 VMC 20 with DC drives.
    I bought the machine a couple months ago. It was having some weird spindle drive issues that I seem to have sorted out (with the original not rigid tap spindle drive)
    The machine had a 1400-4 cpu card and a 1010-1 spindle drive card (not rigid tapping capable)
    I bought a 1010-4 spindle card with rigid tapping EPROMs from ITSCNC. I also bought the max memory upgrade(422k) for the cpu
    As I have mentioned in other posts- adding rigid tapping is kicking my butt. I donít normally have hours upon hours uninterrupted, but today I decided to get it done.
    I checked every wire, connector , and jumper , parameter in the drive and the CNC. A few weeks back I was thinking something wasnít right in the cnc parameters, but Iím new at this Fadal thing.
    I need to call ITS next week and ask them a simple question, but if someone here knows the answer, Iíll keep looking for another problem, I have the rest of today and tomorrow to spend on this.
    My CPU card is 1400-4 , but I think some weasel swapped the EPROMs for an older version that does not support rigid tapping ? There is no parameter y/n for rigid tapping and the gain and ramp parameters that I thought were for rigid tapping may be for the other drives??
    Can CPU EPROMs version V91.3f-3 work with rigid tap EPROMs V92.1Z?
    Based on the fact that the machine had the WIR-0160 (rigid tapping cable) running between the CPU cabinet and the drive cabinet, had an encoder and cable run to the Baldor H2 Vector drive, I had assumed that the seller took the rigid tapping spindle card .
    I never dawned on me that someone may have swapped the CPU EPROMs too
    I had asked ITSCNC if the rigid tapping spindle card was compatible with all 1400-4 cpu cards and was told yes, but they obviously wouldnít know if something weird happened to the EPROMs
    Is there supposed to be a parameter that says a rigid Tap y/n ( I saw Bob posted in another thread that there was, but he was just saying how easy Fadal parameter setup was, but I wasnít sure if it was a real example)
    Sorry for the long post, Iím about to give up(hard for me to do) and just buy a bunch of compression tap holders
    Keith
    Dec 2015
    Connecticut
    1,095
    26
    360
    Should have mentioned
    When I try and run the spindle now, the spindle never turns, I hear 3 small relays??(clicks) picking up or dropping out, and get and Emergency Stop and spindle overload.
    If I put the original spindle card back in , all is good
    Jan 2019
    Arizona
    817
    77
    281
    As far as I am aware you have to have a spindle drive that is rigid tap capable. if you dont you need to get one.
    if you have the org drive in it and its not rigid tap capable its not going to work no mater what you do
    Dec 2015
    Connecticut
    1,095
    26
    360
    The rigid tap spindle card is in now(or was) itís on the bench for these pics.
    The question is the rigid tap spindle card version compatible with an older version of the CNC88HS firmware?
    Edit
    The two cards Iím trying to use together are in the pic
    Sep 2014
    Georgia
    578
    7
    97
    You may have too old of a software version. You should have a parameter in setp that literally says rigid tap yes or no.
    Itís on the right mine say high torque/ rigid tap
    There are other settings aswell. Itís not as easy as just adding a rigid tap card to a normal machine.
    Need to make sure you actually have the correct encoder. Then you need to program the Baldor drive correctly. I think I have instructions somewhere. Then make sure you machine software is new enough. Then there are a few parameters that need to be adjusted including rpm factor and some others.
  6. Likes macds liked this post
    Dec 2015
    Connecticut
    1,095
    26
    360
    Thanks a lot
    Iím pretty sure that I donít have that High torque rigid option.
    Iíll talk to ITS and get the latest EPROMs, then Iíll make sure I have the correct resolution encoder, right now I canít get far enough to try it.
    I have the setup sheet for the drive.
    Again , thanks . I was pulling my hair out. Itís easy to go down the wrong path when your starting point is not what you thought.
    Aug 2013
    New Mexico
    113
    40
    Quote Originally Posted by ripperj View Post
    Thanks a lot
    I’m pretty sure that I don’t have that High torque rigid option.
    I’ll talk to ITS and get the latest EPROMs, then I’ll make sure I have the correct resolution encoder, right now I can’t get far enough to try it.
    Again , thanks . I was pulling my hair out. It’s easy to go down the wrong path when your starting point is not what you thought.
    At least upgrading the eproms on the 1400 card is alot cheaper than rigid tap eproms. No clue why the difference.
    Couldnt live without my rigid tapping on the fadal.
  9. #8
    Feb 2009
    Midwestern MN/Wi USA
    1,364
    74
    379
    Its is your 1610-1 thats too old not an eeprom
  10. #9
    Dec 2015
    Connecticut
    1,095
    26
    360
    Quote Originally Posted by Speedie View Post
    Whatís your confidence level on that? I be pretty excited if thatís the case.
    It was the 1610-1 board I was asking if it had too old a firmware version. There is a sticker on mine that mentioned EPROMs , I should have been more clear when throwing the word around.
    Thanks for helping out
  11. #10
    Sep 2014
    Georgia
    578
    7
    97
    Isnít the 1610-1 just 6 EPROMs?
    Technically you could just do the software update if you had the tools.
  12. #11
    Dec 2015
    Connecticut
    1,095
    26
    360
    I seem to have some weird version, got off the phone with ITS and I should have the High Torque/ Rigid option like Ian posted.
    I bought version 96, Dan said thatís the one they recommend with -4 cards.
    Hereís my page two
  13. #12
    Dec 2015
    Connecticut
    1,095
    26
    360
    Iím going to call my machine
    BOAT
  14. #13
    Sep 2010
    Oklahoma City, OK
    4,697
    808
    1937
    What happens if you activate the Hi-Torque option? Does it magically apply the rigid tap option?
  15. #14
    Dec 2015
    Connecticut
    1,095
    26
    360
    Quote Originally Posted by Cole2534 View Post
    I should try it before I put the new card in just in case someone else runs into the same bind.
