Fadal CNC88HS testing with restricted Z height
Likes Likes:  0
Results 1 to 4 of 4
    Dec 2015
    Connecticut
    865
    22
    265
    Default Fadal CNC88HS testing with restricted Z height
    Before I drag my new to me Fadal VMC 20 with CNC88HS to its final resting place,(it’s in my shop, just not in correct place) I want to power it up and test it as much as possible.
    I don’t want to hack a hole in the ceiling in its current location to allow full Z travel.
    I have never used this control before, but have read the manuals and watched videos.
    It would seem I can power the machine , hit the green reset button on the back and then jog the axis and run the spindle?? Initiating a tool changer will be bad as the cable chain will get mashed against the ceiling.
    If things don’t go as planned, hitting the red slide hold button should stop axis motion and E-stop will shut down the servos and the spindle too- right?
    As long as I don’t Cold Start with restricted Z I should be ok???
    Keith
    Sep 2014
    Georgia
    475
    7
    81
    You can cold start the machine with the z lower than it should be. But then the axis stop will not be set correctly and you can easily over travel. But it will allow you to do everything you want and it actually won’t let the z go more than 4” up from wherever you cold start. Be wary though a tool change will crash the atc. The x and y will be set appropriately to allow you to work the axis and test everything out.
    Feb 2005
    9,034
    13823
    10687
    Like Lanagos said, you can CS it anywhere (which can be a BAD thing), but in your case,
    not a bad thing.
    And if you do crash the tool changer, its no big deal, I've had them crash quite
    the number of times and never a problem. They just bump into the head or the spindle,
    and then retract with an error about 20 seconds later.
    Dec 2015
    Connecticut
    865
    22
    265
    Thanks guys, Bob- that’s good to know, but I’m going to have a trigger finger on the e-stop! Slide stop???
