Fadal G41 programming stops at 2nd line
Results 1 to 8 of 8
    Dec 2005
    Iowa
    242
    22
    Default Fadal G41 programming stops at 2nd line
    Hi I,m still learning this 1998 Fadal 4020 My problem is it stops @ line N50 Here's the code
    N5 018 RAISED
    N10 Tool Call
    N15 G0 G17 G40 G80 G90 M5 M9
    N20 T4M6 (.25EM
    N25 D4 H4 E2
    N30 X-.6 Y-1. S4000 M3
    N35 G1 F10 X-.25
    N40 Z-1.0
    N45 G41 X-.125
    N50 Y1.75
    N55 X.25
    N60 Y-1.5
    N65 M30
    @N50 spindle and travels stop. Table is at Y 1.875
    Graphing stops also If I remove the G41 in N45 it will finish the code
    I'm stumped As always thanks for the help
    Sep 2010
    Oklahoma City, OK
    5,485
    1059
    2392
    Probably a lead in error. Upload the code to the control, that snippet should be enough, and when the upload is complete type SUM and then hit enter. It'll tell you why it stopped.
    There's probably a way to display that message without that effort, but I don't know what it is.
    Dec 2005
    Iowa
    242
    22
    Adding a G1 to each line didn't solve it. This is hand coded at the machine
    Dec 2005
    Iowa
    242
    22
    I found the problem .I didn't have a G40 at the end. I thought the M30 would cancel it
    Sep 2010
    india
    1,371
    75
    262
    Quote Originally Posted by garychipmaker View Post
    M30 does cancel radius compensation, at least on Fanuc.
    Moreover, your program was stopping much before M30.
    Therefore, I believe, you may have some other problem, such as wrong nose radius in the tool offset.
    Jun 2012
    Michigan
    5,898
    5568
    3759
    N20 T4M6 (.25EM
    There is no ")"
  7. Likes Bobw, Nerdlinger liked this post
    Sep 2018
    17
    11
    6
    Always always always cancel any cutter Comp, Canned or height offsets after each operation.
  9. Likes Bobw, Nerdlinger liked this post
  10. #8
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    Quote Originally Posted by sinha View Post
    Yeah, what's the value in your tool radius register? I know you said it's working now, but still, just curious. In most cases the G41 move has to be at least as great as the radius of your cutter.....is your cutter .125" or smaller? (you're moving from X-.25 to X-.125 so that is a .125" move, so it could be trouble if your tool radius is .126" or greater. 99% of the time cutter comp errors are because of this.
  11. Likes Don Davis 87 liked this post
