aarongough
Stainless
- Oct 27, 2014
- Toronto, Canada
Hey guys,
I have a 1995 Fadal VMC15 that is intermittently losing its home position in the middle of a program. This morning when starting the machine up I checked that the slides were aligned with the cold start markers, cold started the machine and then had it move to home. All went as expected there.
Running the first program of the day I hear a 'brrrt' and turn around to see it cutting a nice slot through the middle of one of my fixtures before finally the endmill gives up and explodes... Machine did not fault out.
I move it back to the cold start position and re-cold start it, and then tell it to move to home. However rather than moving in the positive direction it tries to move in the negative direction. My normal home position is with the table all the way forward, but it's trying to move all the way back instead...
The machine is actually commanding this move as well, the control shows -203.20mm in the 'distance to go' if I hit feed hold during the homing move... Turning the machine off, and then cold-starting it again consistently produces the same behaviour. Really weird that it has the length of the move right but it's going in the wrong direction. It's like a bit flipped and now it thinks the home location is a negative number rather than a positive one.
This is the second time it has happened. First time I did a little investigation, couldn't find anything wrong and figured it must have been a stray cosmic ray flipping a bit. All was well after re-setting the home position, and it stayed 'fixed' for a bit over 2 months with no issues until today.
Any thoughts on causes here? I'm just wondering if anyone has seen this symptom before and knows a likely cause... I hate intermittent faults!
I will try the following but would appreciate input!
- Test voltages on ATX supply in cabinet, maybe replace 'just in case' because I know intermittent or fluctuating voltages here can cause some very weird issues
- Test control battery voltage, maybe the battery is bad and causing some weird issue? Strange if it's causing problems when power is on though...
- Pull out all the control cards, clean them with compressed air, clean the edge connectors and backplane, re-seat boards
- Double check control to servo card cables and connectors
This machine was previously a graphite machine so I know there will be an electrical gremlin or two over it's lifetime, but I have already cleaned it *very* thoroughly, also previously replaced all contactors and relays just to be sure and it has otherwise been performing flawlessly since then...
Thanks guys!
-Aaron
Thanks guys!
-Aaron
