macds
Hot Rolled
- Jul 24, 2008
- Milverton, Ontario, Canada
I recently had the spindle drive go down on one of my Fadals.
Been through the troubleshooting list, none of my machines have the keypad for the Baldor drives. Makes troubleshooting tough.
Im getting error #10 when trying to start or orient the spindle.
Power into the drive is good, control card is good, getting command signal into the drive, just changed out the encoder to the new "accucoder" sealed unit.
Zero power out, load meter pegs, control errors out. I can reset with no issue, but same problem.
I tore the Baldor vector drive down today, could not find anything obviously cooked. The only thing I'm not sure of, looks like a big contactor in behind the front board.
I havnt had the opportunity to test it YET, but it seems strange to me. Why put that inside the drive? Is that normal?
I could only see the large 10amp slow blow for fuses, the IGBTs all looked ok. No cracking or fissile material surrounding them.
Anyone have any experience with fixing one of these?
Does anyone know what BALDOR model # it might be?
Seems they were in cahoots with Fadal to keep the ID of this drive under wraps.
