yetiking
- Jan 2, 2011
- California
My Fadal apparently does not like to be sat idle for months, who knew.
after a several month hiatus I flicked on my Fadal to scrolling green font and no response from any key input. after a bit of research and following the diagnostics flow charts I found that my 1040 battery was dead. after the battery was replace and a new power supply was Installed for good measure, the machine is still not responsive to any key input and starts up with "Unrecoverable memory error at 0012....spindle controller does not respond to #48.....no parameters bla bla memory needs to be zeroed"
With a Jumper on J2 jumper on 1040 cpu board I can boot to diagnostics mode, but again no key inputs work. The CPU board led does not blink and neither does the y axis board 1010.
I'm desperate for some expert advice.
