garychipmaker
Cast Iron
- Dec 2, 2005
- ia
I'm getting a odd move in g41 while milling a groove in a triangle pattern. At the end of the last move which is from X -1.456 Y0 to
X-2.235 Y0 which is back to the start of the groove. The problem is the machine makes a Y move from y-.0625 on the screen which is half the .125" endmill to Y+ .042 before the Z+.25 move. Which gouges the side of the groove made by the first line in the program
from X-2.235 Y0 to X0 Y3.0 I would have used G1 moves but the design has another triangle pattern within the outer triangle so I thought the G41 would be easier. as always Thanks for your help
