Fadal odd move in G41
Results 1 to 8 of 8
    Dec 2005
    Iowa
    246
    22
    Default Fadal odd move in G41
    I'm getting a odd move in g41 while milling a groove in a triangle pattern. At the end of the last move which is from X -1.456 Y0 to
    X-2.235 Y0 which is back to the start of the groove. The problem is the machine makes a Y move from y-.0625 on the screen which is half the .125" endmill to Y+ .042 before the Z+.25 move. Which gouges the side of the groove made by the first line in the program
    from X-2.235 Y0 to X0 Y3.0 I would have used G1 moves but the design has another triangle pattern within the outer triangle so I thought the G41 would be easier. as always Thanks for your help
    Sep 2006
    SW Wisconsin
    759
    241
    280
    Make sure your G40 is after the Z clearance move.
    Ed.
    Dec 2005
    Iowa
    246
    22
    Quote Originally Posted by atex57 View Post
    Ed.
    The gouge is made before the z move
    Sep 2010
    Victoria Australia
    4,165
    1777
    Ed.
    Hello Ed,
    Post a copy of your program here for the Forum Members to look at.
    Regards,
    Bill
  5. Likes Bobw liked this post
    Sep 2006
    SW Wisconsin
    759
    241
    280
    Quote Originally Posted by angelw View Post
    Hello Ed,
    Regards,
    Bill
    Gary is the one with the problem.
    When I was first learning G code and cutter comp I made the mistake of putting G40 before the Z clearance move. As the cutter was rising to the clearance it was moving sideways to the center of the tool. After a couple broken tools I figured out you have to clear the part THEN cancel comp with G40.
    Ed.
    Sep 2006
    SW Wisconsin
    759
    241
    280
    I think I know what happened. On the last move the machine wants to go to the end of the line you have programmed not allowing for any tangent points.
    Did the cutter appear to go half its diameter beyond where you wanted it to stop?
    Ed.
    Sep 2010
    Victoria Australia
    4,165
    1777
    Ed.
    Hello Ed,
    Sorry about the name confusion; I looked at Gary's reply to your Post and inadvertently focused on the name Ed.
    What you're saying above about cancelling CR Comp above is unusual at best and improbable in my experience. I would wager that there was something else in the format of your program that caused that behavior.
    I can't say that I've ever seen a programming example of using and cancelling CR Comp in any programming manual for Fanuc, Yasnac, Okuma etc., where the CR Comp has been cancelled after retracting to a Z level clear of the part. There are examples in Fadal Manuals and how the tool movement performs is contingent on whether Format1 or Format2 is selected for operation, but there are many program examples showing CRC being applied and cancelled in an X and or Y move.
    Regards,
    Bill
  9. #8
    Dec 2005
    Iowa
    246
    22
    I think I found the problem it had to do with the lead-in.I was starting in the left corner of the triangle and changed to a 90 move from the bottom of the triangle. Thanks guys
